What is the best fluid to run in an original TH400? (No synthetic please / No Type F please) -
Matt Frediani
California (Nor-Cal)
GMC V2500 Camper Special
TBI 5.7 350
I need to change the fluid , install a pan with a drain p lug/ filter and seal up leaks on my OEM V2500. It has a TH400 and I want to find the right oil to use.
I want to stay away from synthetic to avoid leaks. can you please help me with a brand name and where I can order it?
Thx
Dexron III is recommended for the older GM transmissions.
Dexron VI will work in a pinch, but may affect stall speed and other functions.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
“Synthetic fluids cause leaks!!” is another myth that just won’t die.
If the trans isn’t leaking now, synthetic won’t cause it to leak.
Valvoline synthetic is about 25 bucks a gallon at AutoZone. Supposedly it’s even cheaper at Walmart, but I have never seen it at my local store. For 25 bucks a gallon it’s pretty hard to beat that price
nvrenuf
Mobile, Al.
Why not Type F ? I ran it I’m my old truck and never had an issue. I was told it has better anti foaming additives and a higher boiling point.
Carb'ed Vortec 350
I can't get Dexron III here, so I switched to Dexron/Mercon V.
I'm running the Valvoline Dex/Merc in my 1980 K25 with a TH400. Works great. I run the Valvoline MaxLife(which is the synthetic Dex VI version) in my 2011 K1500 Suburban and have never had an issue either. The Standard Dex/Merc is a non-synthetic Dextron III replacement while the MaxLife is Synthetic. I ran the MaxLife for a while after I first got the truck and had no leaks or issues either, but it isn't necessary.
The Standard Valvoline Dex/Merc is only $13.97/Gal at my local Walmart
https://www.walmart.com/ip/Valvolin...viuqhYLWNe0d7KVU_4xoCtEcQAvD_BwE&gclsrc=aw.ds
Maxlife is ~$17/Gal there too. They generally have them both in stock, as well as oil and coolant for significantly cheaper than the local auto parts store.
73c20jim
Tombstone, AZ
Since you are only dropping the pan the amount of ATF you add is a small percentage of the total amount in the transmission, I don't think it will make much difference what you add..
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Dex iii
Turbo4whl
Downingtown, PA
Wayne
Dexron VI is the replacement for Dexron III.
My question for everyone, how can Dex/Merc replace 3 different Dexrons and 4 Mercons?
The answer is it cannot! Different friction modifiers and viscosities, just to name a couple.
@Matt Frediani , use Dexron VI.
78C10BigTen
pennsylvannia
C10 BIG TEN
Idk if its dex or mex or both but this is what i use in all my vehicles.
Ask GM and they will tell you it works great for all applications of Dexron, Dexron II, Dexron III and 2006+ needs Dex VI. But they also dont want you to ask how and the tsb for it has some cover-ass-wording sorta
ChevyJGP
