Advice on Transmission Fluid Change for 1980 C10
Hilllbilly
PNW
Elon
k20, c10
This is amazing :eek: :popcorn:
So AlabamaDan,,,, did ya figure out what grans you have ?
You should get a book or service manual for a 1980 chevy truck and read that
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
It 99% does not have a drain plug,which is why I said use an upside down trash can lid over your drain pan,otherwise you are going to have a mess. Yes I'm recommending adding a drain plug,and drain and fill the transmission pan on the same day you do your oil changes until you've done at least 4,that will get most of the fluid changed out.
I set my drain pan on a sheet pan (extra large baking pan 18”x26”) to catch the drips. But a trash can lid is probably easier to find
CalSgt
CA
Casey
Just realized I jumped on a dead conversation…
duncan_schawalder
