Marine Corps Moderator
I will have to get some pics later. It's dark now.
You don't have a flashlight? LOL I know you are new... We are pic Hoe's here...
Carb'ed Vortec 350
After a good workout, the back was hurting, so I used the front of the hood, which is just at my lower back, and leaned back towards the windshield to stretch and crack my vertebrae back into alignment. So, I guess this falls into What did your square do for you...lol...
FireTruck1984
Michigan
1984 and 1984
New aluminum trans pan for the TH350..Cork gasket this time, the rubber one that came with the pan leaked badly. So far this seems to have did the trick, no leaks.
Would that also fall under "Putting Your Square To Work". :happy175: :happy175:
WFarm
Central Virginia
K5 Blazer
Today I received my new grill and headlight bezels from LMC and installed them. Love it! Although I’m a fan of just about anything chrome plated!
FireTruck1984
Michigan
1984 and 1984
OH Shoot ! I wish I had known you were adding that Grille..
I have one in perfect condition to sell.. And Bezels . Oh Well
Looks Great !
Sold to @Mr Clean
Looks Great !
Is it the one in the pic? PM me how much.
I decided to get some pretty brake line clamps.
84GMCSierra
Supporting Member Air Force
Central Arizona
C2500
found a set of running boards locally for $30. He was going to throw them away after taking them off of his 83 C20. Luckily I found them on Facebook Marketplace. Got them mounted today now just have to have some steel supports for the steps made and bolted to the frame. All I have is the rear support attached to the back of the cab and several bolts and nuts attached to the flange on the rocker panels. Next up will be to see if I can modify the other boards I have to make a rear piece for each side, lol
rusted nuts
Pa.
Jeffrey
k20
4cly diesel
Moved junk away from it and found some battery cables to hook up 2 battery to spind that little diesel over so I can back it out of the shed.
Camar068
Air Force Supporting Member
10 yrs Air Force
wish the running boards ran behind the rear tire.....be an awesome step to get into the truck. But I don't think they'd look right.
wisco11
