idahovette
Weiser Idaho
Perry
K20-K10
Where to start?
Replaced both tanks, cleaned the lines, rebuilt the carb, fixed a fusible link, troubleshooted the electrical system, cleaned the fuel pump, fused the lines again, resealed the AC compressor, fixed a couple tires, rebuilt the front end, sprayed the underbody with paint, installed a large 2 micron fuel filter, and fired it up! Got it running after at least 8 years.
Wow, what do you do in your spare time?.........lol
Where to start?
So what did you do after lunch? Dang it didn't read Idahovette s post,he beat me. Grrrrr
86burban
Oklahoma
Marcus Buchanan
Crew cab C30
I did an MTV Pimp My Ride customization to my 1984 C30.
hoagster
California
K10, 1500
5.3l
@Powerhouse Ranch If you haven't found a lower hose yet I ended up using a Gates 21849. 1.75" at both ends and clears the belts and frame nicely
What size oem rubber did you order, I have new ones but they are to small width wise top and bottom. The part number I have is 32-0970, I could just shae them down. My other issue is the nut certs for the A/C condensor!
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
What exactly do you need Mike, I'm not sure I understand your question.
hoagster
California
K10, 1500
5.3l
radiator support bushings, do you remember what size you used?
CalSgt
CA
Casey
Sorry Mike, I dug through a box of old used ones and still had to trim them to fit better. I also had an old piece of rubber weather-strip from something I used to support the entire length along the bottom of the radiator since the instructions said to.
CalSgt
CA
Casey
Also for the rubber condenser nutserts I want to say they clear once they are tightened down. I may have trimmed the bolt a little after they were tightened down too but cant remember. I can take another look next weekend for you.
hoagster
California
K10, 1500
5.3l
Thank you, Yea I have a couple of hurdles like the nutcerts you mentioned.
ChuckN
Bellinham, WA
Chad
Got the plug wires in, new plugs, new header gaskets, just need to re-clock the Edelbrock fuel pump for the fuel line and finish putting in the custom 0/1ga battery cables. Then it’s time for fire up.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Had to reach behind the dash to wiggle the bulb holder for the 1st time since March.
Dammit- hope this is a weather fluke and not a sign that more work is needed.
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
Got the new 427 all stripped down and in the shop. Going in the C30 hopefully soonish. What a beast of an engine.
Also got the core support, fenders, inner fenders, and hood on the k20 before i quit, but its too dark for a good pic. Only held on by about 8 bolts, but its on. More to come tomorrow.
drewd
Shawnee KS
Drew
400 sbc
new seats, new retro sound radio whit 4 new Kicker/Fosgate speakers and Brother 6x9 rear bracket and under seat Sub! :)
@TPISly-C10 curious how you like this set up after a few years? I was thinking of something very similar
Strick
Dunn, NC
Harold
C20 Crew
Like I had nothing else to do...I took on a new project. I have been wanting another "run around truck". This thing is going to use up some parts that are just sitting around.
I've got the bug for another one, been scouring marketplace the last few days haha. Want something to just beat around in that'll haul more than my C10 will
JohnJ1984
