Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Gave it it’s first bath in months to make it more pleasant to work on.
Rebuild on the D60, 14ff, transfer case, installing a new nv4500 and ORD custom 3” lift springs with bilstein 5100s.
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
Months? What is the world coming to?
@Vbb199 ignore the trailer its like 15-20 years old, but the tractor and other machinery behind it and ones not pictures are relics. yours is a tasteful gem as the kids say
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Looks like my kinda place to live! (Minus the snow )
That looks like some cool stuff hanging out in the weeds and brush!
yeah and that plant next to my stepside trailer you said was ditch weed? oh its ditchweed and it was also a LOT bigger but another plant/tree overhang hid it well. Most of that doesnt grow in the shade like that. But the thing was full of.. err.. flowers? and because it was the only green thing left over there when i checked. wowser, hopefully the DEA doesnt come shoot my dog, burn the neighbors house down, blow up my truck, and unsuscessfully kill a wild nonharmful plant
and this is all in a no-knock, too
I should take a tour next year with the DSLR after I cut the weeds down and make an albulm.
here is what my truck looks like now, only the pic is from almost exactly a year ago as i prepared the truck and went full in you can see what the scenary kind of looks like, except
Here is most around jan-feb
You mustve mounted your tach on the column :p
In my defense, most millenials wouldnt even know what coil negative is, or where its at :flipthebird:
They're still struggling with what a dick and **** is
:gayfight:
so its fair to assume youve mastered both dick and ****? I Knew it. Its okay though, Im an ally
Decided that I was tired of it running like crap and that it was likely an intake leak that was making it run so bad. Also decided I was tired of it leaking and that I should just fix things now instead of waiting to do it when I do the motor swap sooo....
Drained the coolant and soldered up the inlet on the radiator that has been weeping for the last 6 months.
Then adjusted my steering gear box to take some of the slack out and pulled the steering input out to rebuild the input assembly that has been leaking for about 3 months. I’m hoping that will take care of the slop in the steering and also stop the major leak I’ve had for a while.
Then I started tearing down the top of the engine to remove the intake, but a storm moved in and it got cold, wet, and dark so I decided to leave the intake on and get a fresh start in the morning.
boarder421
