Tried to crank it to drive the rest of the week. Think the ignition module may have taken a dump. Got fuel and compression. Haven’t checked spark. Was a long day at work, not in the mood lol
Sent from my iPhone using Tapatalk Pro
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
More timing tweaks- backed it down to 7 BTDC ( clatter is back, dammit ) and dog city. Put it to 9 tonight - clatter be damned.:p
Also discovered the joy of Seafoam- sucked in thru the little cruise hole.
Smoke, oh my - LMAO playing mosquito fogger :D.
Then, adjusted the idle .
Experiments over fir the moment.
Big Chip
Michigan
Kevin
C35
Ordered one of these today so I can think about getting my exhaust done. I’m going with A-body headers and figured I should just change this now to get the exhaust up a little higher for when it gets lowered.
I’ve got a bunch of stuff sitting in my cart at Summit trying to get a bigger order since they are doing a one time 10% account credit up to $100 if you use your Summit card.
eskimomann209
Modesto
Marcus
Those look sexy. Mine uses the stock xmember. It’s causes my exhaust to drop below the frame in that spot but the rest is nice n tucked. But I really wish I spent the money and bought one.
Big Chip
Michigan
Kevin
C35
I am undecided about 2.5” or 3” exhaust so I thought this was the way to go. I’ll probably go 2.5” but we’ll see when the time comes.
Poppy 87
Bloomingdale GA
R10 Silverado
Are those bolt in or weld in cross member?
Sent from my XT1254 using Tapatalk
jjester6000
Illinois
Jack
C1500
After this happended to my flywheel (2 years after the fact) I actually replaced it.
I also upgraded to an 11 inch clutch.
I even "rebuilt" my transmission.
Using my "Transmission rebuild kit.
Now the clutch actually works and doesn't rattle.
Paladin
"Teufelshunde"
Wichita Falls, Texas
C30 Silverado Crew Cab Dually
Got around to sanding, primering and painting my 'Winter hood" as there was a nice warm breeze through the carport today. Yes, I change my hood between winter and summer, lol. Didn't come out to bad for a rattle can job. Numerous adult beverages were consumed between coats of primer (3) and gloss Shadow Gray (6).:cheers:
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Did some more Seafoam at lunch and let it sit until 5, when I left.
Probably got 1 more treatment left in the can.
Got home and played with the idle speed a bit more, and noticed a tire that looked low.
Yup - a nail in it, too .
Too late to hit Discount, so shot some FixaFlat in it, drove it a mile or so, and retopped off the tire.
We see how it looks tomorrow.
Poppy 87
Bloomingdale GA
R10 Silverado
What is the difference between a winter hood and a summer hood? Insulation?
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Got my air horn installed under the hood and working. Just need to tidy up wires and screw the button to the dash. I decided just to buy a button rather trying to chase horn wire. Kinda proud I figured out the wiring because I'm not too familiar with relays. One step closer to getting my safety inspection and get plates and tags.
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
Added a wideband O2 gauge to help with the tuning. temporary mounted with velcro :shrug:, I will most likely remove it when im done tuning it.
eskimomann209
Modesto
Marcus
Why the seasonal hood?
Oliver90_08
