RangRayy
Kansas City, Missouri
ryan
r10
warmed up and timing set at 8 degrees
got everything warmed up and timing set at 8*BTDC. bear with me I have never done this before and all I knew was anywhere from 4-12* for stock 350s.
any suggestions if it doesnt sound right would be appreciated.
again this is with open headers into 3-4ft of 2.25 pipe
https://youtu.be/xL1-jeWt6j8
Willi2ds
Colorado
Derek
350ci
Added a stripe and a bed cover
74 Shortbed
You're total is what's critical, 36* all in by 2800 is ideal, but that is dependent on compression and fuel being used, you don't want detonation so if it rattles under load need to back it down a degree until it stops, you're initial will be what it is, then make a note of that for later reference if you have to take the distributor out again.
Slick_james187
Redding, Ca
Darren
Suburban c10
454, 7.4L
Cleaned, new gaskets and freeze plugs, carb rebuild, new timing set and lifters, and some smog legal headers for my 40 year old 454 :)
Sent from my SM-N900V using Tapatalk
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
What headers are those?
Slick_james187
Redding, Ca
Darren
Suburban c10
454, 7.4L
Slick_james187
Redding, Ca
Darren
Suburban c10
454, 7.4L
They say 4wd only, but they look identical to mine and they are on a 2wd
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
I was looking on Summit and they have Doug's Tri-Y's (which claim to be CARB compliant in some cases) that look more like yours than the Thorleys. I can see the air injection ports on yours but without a CARB compliance tag welded on to them you're going to have a problem with the emissions test.
Slick_james187
Redding, Ca
Darren
Suburban c10
454, 7.4L
My smog shop didnt even look twice at them. They are old and once i got the truck back together they look like they have been there forever.
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
Sweet! I'd be sure to go to the same shop every time just to avoid any future problems. Noticed it's running pretty clean on the sniffer, wish I could say the same for mine.
Slick_james187
Redding, Ca
Darren
Suburban c10
454, 7.4L
Hell yeah, this shop did me good! The motor is all original, being 40 years old it runs super clean! Had to go through every hose on the truck to fix vacuum and evap leaks, and tune the carb but it has no cats so it is easy enough
robert8096
Goose Creek SC
Robert
Painted the new crate engine.
Sent from my SM-J700T using Tapatalk
Moderator Administrator
It's pretty. Should run great new. New paint always makes them run better.
CRM
Pasco, Washington
Casey
K2500
350 CI
Installed new speakers in the corners. I know the brackets are cheap looking but they didn't cost anything and the seat hides them. I'll clean up the wiring once my amp gets installed. The sound out of them is 100% better then the previous speakers I was using.
Johns C10 Hubcap
