Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
Made sure my mating surfaces had the same, proper, finish.
What ci block is that?
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
Finally pulling the passenger tank. Much easier than driver side.
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
I was going to say the same thing.. I kept pushing my tank dropping off as well for as long as I could, then once I did it I was like.. c'mon, really? Why didnt I do this months ago? Easy.
And yeah, floor jack "helper" for the win. Same for when you go to reinstall - set it back on the jack and let it do the "heavy lifting" in place. :D
I like the fancy jack
Chevrolado
McKinney, TX
Dave
1977|2006
K10|1500
5.7|5.3
Pro-Eagles are legit. Expensive.. but incredible.
I've jacked up from the pumpkin in the back and rolled the entire truck sideways a number of times to pivot around my shop using it. :D They hold up so good.
Originally designed to support the offroad race trucks out in the desert and stuff - they withstand a lot of rugged work. :D
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
If you have them empty (or seriously close) and use a floor jack to slow re-entry, it's not as bad as you might think. I did it in the gravel carport with the jack on plywood so it would roll.
It's nice having that third hand holding it up while you go after the sending unit wiring and hoses (except I would just cut them because now is a great time to replace them anyway). Don't let the fill tube give you fits either, just manhandle it.
You've got this.
Forgot to mention one thing, leave the hanger brackets on the tank. Remove the 8 bolts holding the brackets on the frame. You will have to push the tank assembly away from the frame slightly to clear where the strap bolts fit in their clearance holes, but the rest still applies. Floor jack for re-entry, especially if any fuel is still present. Be aware of how it goes, it will want to be squirrely if there's liquid doing its dance.
It's a daunting task, not mission impossible.
Dejure
Eastern Washington
Kelly
C15
Finished the tailpipe and rear hanger, only to find the exhaust manifold is leaking on cylinder 1.
Was looking at the tail pipe photos and it took me to my buddy's lessen-learned adventure. He'd done some repairs and his pipe ended up exhausting at wiring he hadn't thought about, or didn't know was there. Melted the insulation and shorted the tail lights and such. After a bunch of groping around, he found the melted wires, repaired them and re-routed the exhaust.
aasleson
Minnesota
adam
k30
Went looking for tail lights for the K10 in our junkyard, struck out on that but did come across a distributor and a factory tach cluster out of a C65 with a blown big block.
Looks like the oil pump drive shaft broke where it meets the pump.
Pieced together one good distributor from the two and swapped it into the Suburban definitely starts easier and runs smoother now.
Terlingueno
Fictional Western Sage
Far West Texas
Skeeter
K20 Suburban
350/SM465
Since I found out about yet another filter that had probably not been changed in 41 years, the filter from the carb to the brake booster, I removed said vintage filter and replaced with a NOS unit. I managed to get it to be more vertical than it was but less than fully vertical per some info from this thread. https://www.gmsquarebody.com/threads/part-choice-brake-system.49409/#post-1066573
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Keeping Discount in business!
The 2 fronts with around 4.5K to the back and 2 new fronts. Uneven wear for sure ...
Tank6x2
You’re Awesome Know That!
Lifetime Supporting Member
Edmonton Alberta Canada
Kurt
C30
350, TH400.4:10 gears 2WD
Creeping FBMP today, does anyone know for a fact if the ram horn manifolds fit without interference on a 350ci SBC??
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Ida kept runnin em lol
I honestly thought they were farther worn than that, especially from the noise ! :rofl:
Oh, well- I am planning on taking Goldie for a road trip to the National Forest with some high school buds next week and new tires seemed like a good plan.
Nborden88
