- Apr 11, 2017
- kansas
- Rick
- c20
A bad diode is going to be a bigger draw the incandescent will show it,but it won't light with small loads giving a false indicator. If he follows the directions I wrote in my first post not varying it he will know in minutes if it's an alternator diode. But he does have to remove all connections from the alternator not just the plug. With a bad diode the battery is trying to push battery voltage back through the alternator to ground via the charging wire which in turn is also connected to battery power at terminal 2. So the incandescent light will light because it will be in series with the alternator.When he removes the alternator from the circuit it verifies it. It could be done with a meter it just complicates when you're trying to teach somebody via text. If he hooked up a meter had a big draw disconnect alternator watchbfor a big drop. Then he still shows an insignificant draw. Then we have to ask,does it have a clock. A radio with memory,an alarm etc. So a bulb it is for simplicity.I wasn’t suggesting otherwise. I know it works but only on bigger draws. But idk how much. I’m not a mechanic by trade , I’m an enginerd who builds **** and like working on cars so I look at it quantitatively.
I’m intrigued, what you mean by using an incandescent bulb specifically to diagnose a bad diode. What does it do different than any other parasitic draw?
Love learning new old tricks.
BTW. Guys that have a meter and know how to use it. The simplest way is put your meter in AC volts mode and check for AC voltage at the charging post and the alternator case.
