- Sep 3, 2024
- Nebraska
- Goober
- C15
I cry every time he puts that shop in a postI am extremely jealous of that shop, sir..
As long as there's no Bondo in them it's a win.Don't worry, I bumped them with the forklift. You'll have the limited edition, one of one fenders soon enough![]()
I am beyond blessed and thankful that they allow me use itI am extremely jealous of that shop, sir..
With that attitude and your work ethic, it's obvious why they would. Yer one lucky phuk, sir. EnjoyI am beyond blessed and thankful that they allow me use it
I built a "fuel" pump to test the LS on the test stand using a small helium tank from work (hospital). I'll be building another just for gear and transfercase oil. Drill/tap a hole in the bottom for an a/c coupler. Then put a blower thingy on the other end with a hose that goes into the fill. Set to 10 lbs or so and pull the trigger. No more pumping with the crappy stuff from local stores getting arm cramps and such.No pics but I changed the gear oil in the 9 inch over the weekend.
My brother went to the Rod Run in Pigeon Forge a couple weekends ago and I told him if he saw any vendors with an old 1979 TN license plate to get me one.You can run YOM plates here if you fill out a form for a one time fee.
He brought this one to me which I thought was cool even though he didn't know my plate number....they both have 697 in them. Removed one letter so its not all over the internet lol.
Good idea! I might have to copy it because it did take forever with the little hand pump I had and 85/140 gear oil.I built a "fuel" pump to test the LS on the test stand using a small helium tank from work (hospital). I'll be building another just for gear and transfercase oil. Drill/tap a hole in the bottom for an a/c coupler. Then put a blower thingy on the other end with a hose that goes into the fill. Set to 10 lbs or so and pull the trigger. No more pumping with the crappy stuff from local stores getting arm cramps and such.
Thought I'd share.
Oh yeah, gear oil is some slow stuff to get moving. Our '75 GMC Burb with the Cadillac running gear, when we got it the rear axle was leaking. You can imagine how much fun it was, trying to get 140W gear oil to pump out of the bucket, with a hand pump... especially since it was in January and close to freezing. Not the best time to be under a Burb.....Good idea! I might have to copy it because it did take forever with the little hand pump I had and 85/140 gear oil.
I gave it a like but could have gone with a YIKES! Good news is new parts is cheaper and easier than that cleanup. Slap a couple new window regulators in it and enjoy the next 40 years of buttery, soft window cranking!You must be registered for see images attach
Today is the day
For those unfamiliar, in '79 and other years there's a clip that secures the L shaped piece to the lock cylinder. That particular clip does NOT come in the kit from Standard, so don't bonehead and break or lose it. It will stop you cold. Lucky me, it's warm out tonight. An extremely easy r&r, and now look at what decades of neglect look like concerning the window track...
You must be registered for see images attachNow, that's a bit of schmutz to get cleaned off. No wonder the window is so crabby.
But after that, this was the best feeling. One more off the list, of the original sins.
Ha ha ha keeps me grounded.
I bought a complete set all key'd the same ignition, glove box and doors and those 2 clips for the door lock pawl were included. Mine looked just like yours!You must be registered for see images attach
Today is the day
Update:Currently very deep into a spare parts and on-hand maintenance bits, hoses, clamps, fasteners, juices and goops inventory...
Cause that's how folks survive in that part of the state..... I'm guessing Alpine is probably the closest big town.... Used to have a musician/songwriter friend who lived in Alpine. When he was going to do some Texas gigs, he and his wife would drive one day to Austin, overnight with his stepson, then the next day go to Houston or DFW.Update:
(all this stuff because I have live/have lived 100+ miles from any parts store for the last 25 years and I don't go to "town" much)
Spares:
Water pump/gaskets- check, self rebuilt starter- check, fuel pump/gasket- check, Edelbrock 1405 caibration kit+rebuild kit- check, throttle return spring- check, couple ignition modules- check, HEI coil- check, distributor cap- check, rotor- check, set of plug wires- check, set of spark plugs- check, alternator- check, fan belts- check, clutch master+slave cylinder+hoses- check, power steering pump w/o reservoir+hoses- check, radiator hoses+195 thermostat+gasket+ heater hoses- check, fuel+vacuum hoses- check, H4 bulbs- check, all other bulbs- check, bunch o fuses+relays- check, wiper blades- check...
Filters:
Wix 51061 x2- check, Wix 33003 x2- check, Wix 33270- check...
Juices:
10w-30 Valvoline VR1- check, 80w90- check, Dexron NP208)- check, Dot 3 brake juice- check, power steering juice- check, green anti-freeze- check, windshield juice- check, air filter oil- check, DeOxit- check, WD-40- check, couple bottles of Techron gas stuff- check, carb cleaner- check, brake cleaner- check, various loctites- check...
Goops:
Axle grease- check, grease gun grease- check, white lithium- check, silicone module grease- check, dielectric grease- check, thread sealant- check, RTV's- check...
Small boxes containing bunches of:
Hose clamps, bolts, washers, screws...
Two rolls of US made electrical tape and two rolls of US made duct tape, roll of bailing wire...
Yikes!
