Vbb199
B-rate Hillbilly Customs
- Jan 12, 2018
- Salisbury NC
- Vince
- 89 Suburban R1500, 79 C10
Since my discovery of worn out side gear clutches in my rear end, and the terrible whine from all the spider gear slop, i will be replacing the unit with a yukon duragrip posi.
That said, i will be temporarily welding the diff solid like a spool until it arrives.
Can i just simply weld the spider gears at all 4 corners? Or will i need to remove the governor **** also to make it like a "open diff"
Some advice before i kick my own teeth thru. Never done this on a G80 posi. Just open diff.
@HotRodPC maybe?
@HotRodPC maybe?
