Vortec 454 7.4l vs Vortec 496 8.1l
Gilderbeast
Fargo, ND
Brett
I've narrowed down my choices for my next build. I am trying to decide what would be the better of the two.
The 7.4l out of 96-00 GMT 400 platform puts out 290 hp at 4000 rpm and 410 ft-lbs at 3200 rpm. The 8.1l out of 2001-2007 GMT800 trucks/suburbans/vans puts out 325 hp at 4200 rpm and 447 ft-lbs at 3200 rpm.
So obviously the 8.1l makes more power but has very little aftermarket support (raylar) and you will pay outrageous money for more power and are pretty much limited to exhaust, intake, and a tune. Thats why I'm looking into the vortec 454 as well. More cylinder head choices, cam choices, aftermarket efi, headers fit better, coil near plugs kits available, and if I really wanted I could do forged rotating assembly much cheaper than the 8.1.
Thoughts?
Arkansas_V8
Proud Redneck
Springdale, Arkansas
Brent
V20 Suburban
If you intend to modify, then 454.
I want a 8.1, it will suit my Suburban just fine, loud exhaust, and a tune are all I need.
1979k10
Las Vegas
Dirty Dave
I would go 454 since you're looking at aftermarket supply. Once you warmed it over a bit the factory specs won't matter.
78C10BigTen
pennsylvannia
C10 BIG TEN
I know a guy that has one... hooked to an allison
Moderator
The vortec 7.4 cylinder heads are supposed to be pretty decent. Keep me in mind if you end up with an unused set :)
Craig 85
Nashville, TN
454/TH-400/NP205
I've had a (4) 454 trucks/Suburbans. 2 carbed & 2 TBI. I've had (2) 8.1's. 1 with a 5 sp Allision, 1 with a 4 sp auto. All where mostly stock. The 8.1 with the Allision had a chip and aftermarket cold air set up. I liked the 8.1 more than the 454 in all aspects. You barely noticed when I had my 30 ft travel trailer on it. I agree aftermarket is pretty limited though even when they were new.
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
If you really want to get into head swapping and all that, like, legitimately spend 3 or 4k and build a 5, 600 hp N/A engine, the 454 is a better base.
If you just want to tow your junk on cheap gas, the 8.1 all day. You don't need Raylar at all to make nearly 600 ft/lbs of torque. They routinely exceed 500 with just a exhaust and a tune.
The reason there's no aftermarket is there's no need for an aftermarket. I can tow my C10 behind my Silverado with a loaded truckbed camper on the back, uphill, with the converter locked, on 87 octane gas.
If you don't want to really build something, the 8.1 is already mostly done.
If you're fine with dumping a few k into something for performance, do the 454.
TerryRH
Jacksonville, NC
Terry
350ci
I vote 8.1 with exhaust and tune. You can open up the heads for a little more if you want, and they even have more cam choices.
TerryRH
Jacksonville, NC
Terry
350ci
:mfr_omg:.....
TubeTruck
East TN
Denis
Suburban K10
LQ9
I was having the same debate with myself and decided to also go with a 7400. Support goes way back and if it breaks I would think it's easier to get parts for. Keeping it stock for a while with the multi efi, then I plan on building it, stroke it, cam it, probably aluminum heads and putting it in front of a 4L80E and an NP205.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
That's the combo, and twin stick the 205 while you're at it.
nixon22
