74Blaze
- Oct 25, 2022
- Nashville, IN
- Gerald
- K5/Blazer
Longish story. Blaze has not been running well for over a year. After throwing new parts at it, checking for vacuum leaks..., I finally came to the realization that it more than likely jumped timing. I put the current engine in it in 2007. It is 290 HP GM Crate 350. Yes, I could put a new timing chain in it, but I have just received a free 383. The 383 came with the '55 Bel Air that a good friend of mine purchased last year. The story goes that it is a fresh rebuild (built ≈20 years ago) that was never re-installed in the '55. The owner had a stroke and never recovered well enough to finish the re-do of the '55.
So what I know is it's mid-90s 350 Block, with mid-60s Corvette 2.02" Heads. What I've been told is that it has 11:1 compression and a Lingenfelter Cam. Also, in it's previous configuration, it was running nitrous. Bore Scope shows that the Pistons look new and have Valve Reliefs on the tops. I'm still trying to figure out exactly what I have. My main concern is whether it has a realistic Cam for my trail-rig application.
Picture of my current 350 and a few the 383 are below.
