carnutjw
- Sep 18, 2024
- Evansville, IN, USA
- John
- R20 Suburban
Messaged ChuckN about the die casts he had for sale and mentioned that I too am working on a 383 build. Although he suggested that I share my build on his thread I don't want to cobble it up with my slow pace. Alas mine is not for a Squarebody but instead for my '79 Cutlass. I have owned this car since August 2017 with the original 305, 2.29 rear, and first a TH200 that took a crap, now a used TH350 that has developed a massive fluid leak at the front end. Since there is a TKX 5-speed, clutch pedal kit, and 3.42 geared rear axle upgrades in my basement I'm planning to do those upgrades first this spring, then the 383 swap this fall. Enough about that- here's the 383 plan:
'89 350 block- roller cam ready, 1-pc rear main, fuel pump boss
Bored .060" over(technically 388"), Scat 3.75" crank, Summit cap screw connecting rods, Summit 17383C-60 pistons, Summit 8802 hydraulic roller cam (218/[email protected], .525/.520 lift, refurbed 062 Vortec heads, Performer intake, to-be modded (per Cliff Ruggles book) Q-jet, Hedman 68608 mid length headers.
Should be about 9.7:1 compression at .005" deck clearance and .041" head gasket, hoping to run 87 octane gas.
Initial boring, decking, head resurfacing done locally, taking to another shop for balancing.
Shooting for about 370hp, 400ft-lb?? Wanting a trouble free cruiser with a little oomph- so what do you guys think?
