- May 13, 2019
- Oregon
- Eric
- K25
- 350-4bbl
i seem to recall a gentlemen who complained to me for about 35 minutes about how you needed a tech 2 like mine to perform a relearn when the distributo is changed or moved.
Is that relevant?
That's only a thing for Vortec engines that have a cam position sensor. You have to set the distributor to 0deg with a very small deviation to be able to even start the motor(which obviously makes it hard to figure out with a timing light). There are some good quality scan tools that can show you the right PID to do the adjustment without having a tech 2(which is really mostly for OBD2)
