Using the 98 Camaro 3wire coolant sensor, pcm 40 Degrees hotter??
Biggin0822
Michigan
kevin
Brand new speed hut gauges and using the above sensor so that 2 wires can go to pcm and one wire to the gauge. Gauge usually reads 158 and pcm reads 198. Any ideas?
yevgenievich
Place
Name
Year
Model
Size
Resistance mismatch for the gauge? I used a pot to adjust gauge to read same as the computer before.
yevgenievich
Place
Name
Year
Model
Size
You can get a potentiometer and install with two closest legs in series of wires running to the gauge. Adjust to read same as the computer is showing. It will not be very accurate at lower ranges and higher ranges but will show correctly for the usual range.
alwaysbroken
