Upgrade order
Old60Driver
1983 K20 Silverado
Houston
Michael
K20 Silverado
Finally got some time to tinker these last few days. Wife worked on restoring the dash while I de-smogged and added headers. Also put in a new headliner!
So with the headers installed, she seems to have a touch more grunt, but I always knew that I wanted to do a bit more for her. I'm thinking an RV cam and heads to go along with a new intake and existing (rebuild) Q-jet. I don't want a high RPM screamer by any means, just something that I can have fun with every once in a while off the light. As such, I'm not looking at a full rebuild or an LS swap or anything.
That being said, should I just do it all at once? I worry that if I put it ALL in (intake, heads and cam) that I may have to futz with her to get her running smoothly, and I'd rather not have to do that while I'm trying to break in a new cam/lifters.
Should I do it in steps, and get her running in-between each step? That seems like a pain in the arse (not to mention expensive in time and gaskets). Or should I just slap it all in at once?
Thanks y'all!
dsteelejr
Hudson, WY
Have you looked into Edelbrock's top end kits? They include heads, intake, cam, lifters, timing chain, all bolts and gaskets. Kit comes with everything you need except rocker arms. You can use your stock rockers or aftermarket rockers up to a 1.6 ratio. I went with Comp Cams roller rockers. Just do it all at once. You said you're not looking to make it a high RPM screamer, Edelbrock's E-Street series have flat tappet cams and are for idle to 5500 RPM. I'm building a 400 small block from a bare block for my '73 C20 and I'm using top end kit #2038, which is rated for 338 HP-389 TQ on a 350 with 9.0 compression. Kit will set you back about two grand.
The intake that comes with the kit is for a square bore carb. If you insist on running that Q-jet you'd have to adapt it or find an intake with a spread bore pattern. You can also buy each part individually instead of buying the kit. You could buy all the parts of the kit minus the intake and buy a different intake.
dsteelejr
Hudson, WY
And thus another victim falls down the rabbit hole.
Really? Was it even worth the time you took out of your day to type that?
I've helped out fellow square body enthusiasts on here, giving away (not selling) hard to find parts to others on this forum to help them with their projects and then there's dealing with BS like this. The juice isn't worth the squeeze anymore.
I'm done.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Thanks y'all!
Do it all at once Mike... like an engine builder would do. I like to set the valves before I install the intake... I find I can see what's going on a lot better regarding getting the lifter on the heel of the cam. Tighten to zero lash and then add 1.5 - 1.75 of a turn down. New lifters... NO OIL ... no problem, just be more gentle finding zero clearance.
With your intake, whatever you end up using, toss the rubber damns for the front and rear china wall. Use The Right Stuff. I like to lay a fat bead on the china walls and let it set up. Then when your ready to install add more Right Stuff goop to the sides and top of your first bead.
SquareRoot
I'm done.
No sense of humor huh? Sorry if I offended you. Maybe take some of that "juice" and make a margarita or two.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
I hope dsteelejr didn't think my comment was directed at his reply. The rabbit hole was in reference to the OP's conundrum. Lol
I knew what you meant. Don't know why anyone would get upset over that comment lol.
GTP51
Melbourne Australia
Geoff
R10 Silverado half ton Stepside
My 2 cents: To save yourself having to play multiple times, may as well do the whole top end $’s permitting and be done with it and enjoy the extra HP.
Cause we all know that it doesn’t stop once you get started on the upgrade path
The Right side of Washington
@Old60Driver
You've talked a couple times about engine options and also about keeping truck original.
Presumably it runs good/acceptable now?
Personally I wouldn't drop a wheelbarrow load of new top end bolt ons and a cam on a stock 80s small block long block.
My idea would be leave stock, stock and buy or build a motor to swap in it if you want more performance.
brembo stickers and red calipers are a very non invasive way toi make it feel faster without actually doing anything. thats not stock tho. But painted calipers are often nice when your wheels are open but that would be very stock either. So this idea isnt panning.. hmmmm
dvdswan
Port Orchard, WA
Dave
Chrome lots of chrome.
Do the swap all at once. But if you're going to drop that much on just the top end of an engine. IMO, I'd spend a little more and just swap the whole engine and get a warranty with it.
Plus, you'd be done with the smog beast that's in there now.
cstew47
colombia
craig
Yeah, I understood your humor. We've all been there. Start adjusting the carb and wind up rebuilding the engine. It's like pulling a thread on a sweater.
Do you even read the subject line or question/content in a thread before responding?
If you do, then I’m really struggling to make the connection between specific engine mods the OP is contemplating and the plastic/chrome/stickers crap from the junk aisle at Vato Zone that you are suggesting here. (And not even plastic chrome engine crap, when the thread is about an engine)
Did your parents have any children that lived?
NateP350
