84-C20
- Dec 6, 2019
- Chevrolet
The thing that makes this a little harder is your exhaust. What I mean is your exhaust on the video at least sounds pretty loud, which covers the noise considerably. I would have bet on water pump until you said it did it with the fan belt off. I'd say test it again when you have time. Remove the fan belt, test. Remove P/S belt test again. If the noise is still there try to isolate generally where it is coming from, as in front of the engine or back. Noises can travel in weird ways sometimes and this might require carefully getting under the engine or above it with engine running. This is NOT going to be coming from rod or main bearings. It really sounds like accessory noise, but if it's not something belt driven then I suppose it's possible it could be something from under the timing cover maybe possibly the oil pump. Let us know what you find when you do more work on isolating it.
