Twisted vacume hose on Quadrajet
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
I just got in my rebuilt Quadrajet this week from national carbs. Thanks to the member who posted the link. I don't remember their name. I noticed that one of the hose seems twisted. I don't think it's twisted to where it is ineffective but I was wondering if I should try and reroute it or not worry about it?
I kind of moved it around as much as I could and it didn't seem to be pinched to where it was closed off. Idk if it's me just being worried for nothing or maybe a problem. Some opinions would be appreciated. Thanks
Snoots
Roger
Jimmy Sierra
350 w/203
Can't believe they'd send something out like that.
I don't think it would be a problem. But for me, I'd try to either a) turn the can or, b) install a new hose.
82sbshortbed
Fuckemall!!
SE Texas
Doug
Kinda what I was thinking.
Looks like it might fit better if the hose had about 1/4 inch taken off of it?
Dougnsalem
Why would you even bother posting something like this? Ummm, maybe just replace the 50 cent hose? If it looks tweaked, why not put a new one on???
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
Yeah dang it, there isn’t even a single crayon reference!
Big Chip
Michigan
Kevin
C35
I got my hose twisted like that once. I suggest you try it and see how it works for you. Who knows, you may enjoy it?
CSFJ
Usually works best if they twist it while lightly flicking the end.
Dougnsalem
It could be cut to fit, but I don't think I'd do that....
Big Chip
Michigan
Kevin
C35
I agree. The twisting is just the setup for actual work to be done. As I recall the twist did NOT affect the performance at all but perhaps enhanced it, sort of like the Venturi effect. A turbo boost of sorts.
Big Chip
Michigan
Kevin
C35
Cutting is bad and I would recommend against it.
CSFJ
I would think anything more than say 45° is apt to be less effective.
Big Chip
Michigan
Kevin
C35
Well, yes, of course you're right on point with that. I can't say that I've even come close to the 45 degree mark but I have to think that's way too much.
blackbeard2011
