Turn signal assembly
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
Order this cheap part incase...
It's in the top end for high beams, mine had little plastic nob broken off.
fnny6770
Pocatello
3500 camper special
Now is the time to add the same switch from a full size GM sedan. It has the 3 extra wires for the cornering lights. You could wire it up when the headlights are on, powers up the turn signal cornering lights. And yes, you need to add the lights.
You need to be more clear about what you're referring to here, if I order a harness for my turn signals everything should come with it I shouldn't have to add three extra wires just to power my trucks turn signals.
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
Read and comprehend, he said the extra wires are for cornering lights, just an extra add on.........if you want
fnny6770
Pocatello
3500 camper special
My harness only has eight wires, the socket was broken on the far left so two wires fell out easily
fnny6770
Pocatello
3500 camper special
Cornering lights to me are your turn signals, so perhaps I should ask what he means by cornering lights?
Turbo4whl
Downingtown, PA
Wayne
Hi Paul, Turn signals are for indicating a turn. Cornering lights are a separate feature to light up the side of a vehicle, while turning, to see what is next to the vehicle.
fnny6770
Pocatello
3500 camper special
Since it's a dual wheel truck it does have lights on the sides of the wheels, but my current turn signal only has eight wires, where would I find a harness with corner cornering wires?
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
See post #14
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Cornering lights were found on lots of high end fancy cars. It is easy to add with the correct turn signal switch.
samelthecamel19
