Transfercase
82chevy350
Van Buren, AR
Joey
C10, K10, K5
well i bought a used transfercase for my 76 for 50 bucks and got some free centercaps and a windshield for 10 bucks lol.. got a hell of a deal
But i installed the 203 and its still popping but not as bad i gotta get this thing ready for the trails
So im looking for a good np203 or a np205
if i switch to a np205 will i need to change driveshafts?
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
Rear driveshaft will be a little short with the 205 but the front should be the same. What trans are you running TH350? EDIT I see in your sig TH350, if you can find a 205 just try to get the rear d-shaft to go with it. The trans to t-case adapter/mount will be different too, as well as shifter.
What popping? Are you saying your original NP203 is bad cuz it pops, but this used one you acquired pops too? Is it possible the popping isn't from the Tcase and might be something else like maybe the CV in the front dshaft?? :shrug:
While on this subject, so you're 76 will be OEM 12 bolt rear axle correct??? I got that driveshaft ouf of the 80 GMC with the NP205/Th350 that has a 12 bolt. The truck I intend to use the NP205 in currently has a 10 bolt rear end. Either of you know the dshaft difference in the 10 bolt axle vs 12 bolt axle?
In the rare event that I don't use that NP205/TH350 rear dshaft out of the 80 GMC K10, I might have one available if you do find an NP205 for yours.
crazy4offroad
Curt
K-10
350/SM465/NP205
The 10 bolt pinion may be a very little bit longer, I dont know for sure but it should fit.
82chevy350
Van Buren, AR
Joey
C10, K10, K5
your exactly right it was the front driveshaft hitting on the crossmember due to the transfercase mounts being wore out...
So now i got a spare 203
But my front pinion bearing gave out yesterday
DOH !!! That sucks about the pinion bearing. But, sounds like you get that and a new Tcase mount, you'll be back in bidness !!!:grd:
swagger
old house in WV
Steve
350/SM-465/NP-205
I have good NP-203 and 205's for sale, BUT... your too far away
Steve
Steve
BTW, where is old house at? Sometimes members are passing thru other cities and states, so sometimes, it's not far away if others know city and state. Wasn't long ago, a guy didn't sell a truck and scrapped it. Had he had his city and state listed, I have a feeling it would have been sold on the forum, a good possibility anyway.
There you go Dave, gotta WV hook up.
krogers98gmc
