towing
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
im thinking about getting a travel trailer.What would the tow weight capacity for my truck be.87 r10, 4.3, t400,3.08 rear. i would use a trailer hitch.Thanks
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
edit: nevermind, misread question. d'oh.
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Well, without beating around the bush, Maybe a max 4500lbs ONLY if you change your rear end gears to 3.73, add an extra trans cooler, and DO NOT TOW IN Overdrive.
It wont be a speed demon, but thats not what trucks are for.
I would say keep the GCVW in the neighborhood of 9500lbs.
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
With that setup I would be looking at pop-up tent trailers.
Jims86
Patterson,Ca
5.7 TBI
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
i was looking at something around 18'. they come in around 3200#
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
ill be retired .so im in no hurry
Jims86
Patterson,Ca
5.7 TBI
Ahh...you have a th 400...Maybe 3.42 would work.
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
i recently switched to the 3.08 .guess ill need to put a 350 in there.
Jims86
Patterson,Ca
5.7 TBI
Why? Lotta 3/4 ton FedEx vans had 4.3's.....its all in the gearing.
I'd run it with the 3.08's and see how it does. My gutless 305 probably has similar power to the 4.3 and I only have 2.56 gears and I wouldn't be afraid to at least try it out.
Jims86
Patterson,Ca
5.7 TBI
Yup...sometimes only A 5 hp and 10ftlb difference.
austinado16
Central Coast, CA
GMC V1500 Suburban SLE
5.7L TBI/4L60/3.42's
If you're not set on a Travel Trailer (TT) I'd highly recommend a pop-up tent trailer. They're a lot more open feeling, and a lot bigger, tow nice because they're low, and don't suck down the power or fuel mileage. A big one, with an 11' or 12' box, will open to 23'-24', with 360 degree views, and features like a fridge, furnace, water heater, electric water pump, roof a/c, sometimes even a built in toilet or toilet/shower combo. Some even have slide out dinettes and pop out kitchen window areas. They typically weigh 2,200-3,500lbs fully loaded and set up to camp and maybe 500-800lbs less empty.
Visit www.popupexplorer.com and www.popupportal.com which are the 2 giant online forums for pop-up (PUP) enthusiasts.
Been draggin' one around California since '07 and we love it.
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
thanks. i'll look into them also.
Chype1
