Tightening down front yoke nut stops NP205 from turning
Mark80K15
Sicamous, BC
Mark
K15
Hello, 1980 GMC K15 SM465/NP205. I broke the SM465/NP205 adapter, so I took the time to apply new NP205 seals/gaskets and the JB Fab twin stick setup. I didn't intend a full rebuild, but I wound up removing everything except the idler gear assembly. In fact the front shaft just kinda fell out (gently) at one point. I've never worked on NP205 before.
Replacing the shift rails went well. Since I had both the front and rear output assembly out, I could clearly see the 2 rails from the inside, the 2 shift forks, and the interlock rod. Seeing these and understanding how they work helped a lot in going through the rail replacement procedure. Once the roll pin is knocked out of the rail (3/16" punch), and the rail is clear of the interlock, there is nothing else touching the rail but the fork and the case itself. I found the passenger rail was kind of stuck in the fork, which probably causes the difficulty that others have reported. Just keep working the fork off the rail, it will come eventually. Brand new and without the roll pin, the rail slides through the fork effortlessly.
So I finished reassembling, applied gaskets and seals, and measured how far the modified rails (that came with the twin stick setup) protrude from the case in each NP205 shift position. The measurements were correct, (and the same as stock). I drew a guide which I posted here:
Mark80K15
Sicamous, BC
Mark
K15
I confirmed that for each NP 205 driving position (4H, 2H, N, 4L), the rail position was correct, and the input/output shafts turned properly. For example, N has each shaft turning (or stationary) independently, 4L has input turning twice for every front/rear output turning once, etc. Everything moved smoothly, minimal noise, etc.
Here's the PROBLEM: The last thing I did was tighten down the nut on the front output yoke. On the bench, I could only get it to about 60 ft-lbs (I think it has to be 120-150 ft-lbs). At that point, no shaft would turn at all. Everything was locked up. I couldn't even move the shift rails. If I simply finger tightened the nut, it would still turn.
If no one has any ideas, I guess I'll have to open the front drive back up (remove front yoke and seal, and rear cover for the front output assembly) and see if anything is reassembled wrong.
Thanks in advance!
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Sounds like maybe a bearing issue. Thrust washer maybe.
Check out GebBuilt on YouTube, he goes through one by the book. He also became a member pretty recently.
Mark80K15
Sicamous, BC
Mark
K15
Yeah thanks. In fact the GebBuilt videos are what gave me the courage to proceed. Since he just became a member, I’d sure like to talk to him… Anyone know how to reach @GebBuilt?
Mark80K15
Sicamous, BC
Mark
K15
Hi all, I still need help on this, if anyone has a similar experience.
Moderator
I am certainly no expert on it at all, but since it is locking everything up, would that indicate that tightening the yoke is somehow causing the idler gearset to bind?
Mark80K15
Sicamous, BC
Mark
K15
Trying to find the problem, I removed the seal housing from the front output shaft, and put the yoke back on. I wanted to see what would happen if I tightened the yoke on with no seal housing. I tightened the nut to 60 ft-lbs, and everything still turned properly!
So clearly there's a problem with the seal housing and seal. When I looked closer at the seal (brand new, just installed), I could see there was a gouge, the same diameter as the dust cap on the yoke. That diameter is smaller than the seal itself (and smaller than the hole for the seal in seal housing).
Mark80K15
Sicamous, BC
Mark
K15
So when the yoke is tightened on when the seal housing is present, the yoke dust cap contacts the seal enough that it actually stops the front output shaft from turning. Did not expect that!
I installed the seal so that its face is flush with the top surface of the seal housing., same as @8:45 of the YouTube GebBuilt NP205 COMPLETE How To Rebuild Part 2. That is also the same as how the seal was installed when I first removed it from the seal housing. However, @ 25:40 of Part 3, GebBuilt shows how the seal is pressed in about 1/4" deeper. This fills a void that is illustrated in this picture of the inside of the seal housing, marked in red.
That void is present when the seal is pressed in flush with the top surface of the seal housing. But then the dust cap contacts the seal. If it's pressed in further as GebBuilt did in Part 3, there will be no contact.
So, is it ok to press in further so the seal is completely seated, and there is no void?
Moderator
As long as it still seals on the yoke, it will be fine.
So maybe I misunderstood before. When it it was tightened and everything locked up, was that just in 4wd, or when shifted into 2hi as well?
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
So what did you replace that is different than stock, besides the twin stick? Sounds like the input stack is to tall, and binds when tightened? Anyway this is a good site to study.
Craig Nedrow
Washington State
K10, K20, C20
This is a good site to help you. I do see the mark on the dust shield, that is not right. Is there a gasket on the cover? Have you tried to use a thicker (or two) gasket on the cover to see if the binding stops? Just trouble shooting.
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
Look at the witness marks on the yoke, you can see where the old seal lips used to ride, if the yoke is pushing into the seal farther than it used to that's definite evidence the seal needs to be driven farther into the case.
But
So long as the inner and outer seal lips will still ride on the shiny part of the yoke I'd drive it in farther.
Mark80K15
Sicamous, BC
Mark
K15
Sorry @bucket , I wasn't clear before. When I said everything locked up, I meant only when the front output shaft is engaged (4H and 4L). The input shaft or rear output shaft were never affected by this problem.
Hey @Craig Nedrow , I didn't replace anything that is different than stock, other than the twin sticks. Yes, there is a gasket on the cover. No, I didn't try a thicker (or two) gasket on the cover, thanks for the suggestion.
I got advice from someone knowledgeable that confirmed what GebBuilt did: press the seal deeper so it completely seats in the housing (see picture). @CalSgt also suggested that, thanks. When I did that, there is no longer any binding. I can see the seal lips are still completely engaged on the shiny surface of the yoke.
Don't understand what changed compared to how it was when I took it apart. Maybe the original gasket was thicker. Whatever, as long as there are no leaks, it should be fine. I'll monitor.
Something else I should point out while I'm at it... there was a rubber seal present when I took it apart, at the end of the front output shaft, and seated in the yoke female spline (see picture). I replaced it, and found out that for my 30 spline shaft, the replacement is from a NP203 kit (TSK-203G). I guess only a 32 spline rubber seal comes in the NP205 kit.
Thanks to all for your help!
H2OnSnow
New Hampshire and Colorado
Rich
Blazer
Have you looked at the service manual for your truck (https://www.gmsquarebody.com/threads/1973-1991-service-manuals.14499/)? What made you decide not to seat the seal fully in it's bore? Why, if GebBuilt ran it all the way home, have you decided to not do that, especially if he is what you are using as your guide on this project? Look at the seal surface of your output flange. You can see the place where the old seal has been contacting the flange. With the seal in your location, where does it contact the flange? Leave some grease on the flange and see what gets wiped off when you install it; that'll tell you how deep your seal needs to be seated to match what that flange has been seeing all its life. Go back to my first sentence again.
Mark80K15
Sicamous, BC
Mark
K15
Hi @H2OnSnow , yes, I looked at the service manual. One reason I decided not to seat the seal fully in it's bore is because before I touched it, the seal was not fully seated in the bore. Instead, the seal was seated so that the top of it was flush with the top of the housing. The other reason is because someone smarter than me said seating it fully would be wrong. Thanks for the advice. To be clear, in the end, I did press the seal deeper so it completely seats in the housing and now there is no longer any binding.
kfrdavid
