Throttle Position Sensor Voltage
Ol Blue 2018
Pensacola, FL
1987 V10 TBI 350
Using my trusty "paperclip", I see I have a code 22: Throttle Position Sensor (signal voltage low)
Using a multimeter I see that I have .54 volts at closed throttle and 3.4 volts at wide open throttle. My service manual says I should have about .5 volts at closed throttle and about 5 volts at wide open throttle.
I am thinking this means replace the TPS. Is this correct?
Thank you and let me know if this sounds right.
Camar068
10 yrs Air Force
not knowing what it looks like, is it possible to clean it?
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Your low voltage is perfect. I can’t even get mine to read that low after boring the mounting holes in order to pivot the sensor. The high one is a problem. It should be 4.5-5V. Did you notice any dead spots? If your throttle linkage is moving like it’s supposed to all the way to WOT, I’m thinking replace it.
yevgenievich
Viktor
sad
very sad
less sad
Verify 5v exists on one of the wires. If reference is good, then sensor likely at fault
Ol Blue 2018
Pensacola, FL
Yes, maybe but frankly if I take it off, it's getting replaced.
I did not notice any dead spots at all. I assume that yes, my throttle linkage is functioning properly.
OK great. I got 5 volts on one of the other wires constantly. Does it matter which one? There is a light color, a dark color and a blue one. The blue one is the one that changes with throttle position.
Thanks for the responses!
1998_K1500_Sub
