the viper mistake
nabeshin
functioning lunatic
Cozad, Nebraska
Grae
Exterior paint looks flawless.
The valve covers would bother me if it were mine. Squares can have chipping paint on the engine, a super car cannot.
yevgenievich
Place
Name
Year
Model
Size
It bothers me,
But have to make space in the garage so I could deal with it
yevgenievich
Place
Name
Year
Model
Size
I accidentally layed couple of marks last week. Today found that someone either took it as a challenge or wanted to mark the area for them selves.
yevgenievich
Place
Name
Year
Model
Size
Got the keys/remote sorted to be correct and it is actually in my garage now vs parked at work. Need to do an oil change and a bunch of minor work including new shifter. Camaro is also on the more approaching list of being worked on again. Cleared off a bunch of parts from top of it and getting ready to cut the fuel tank for fuel injection. Pretty much only parts on top or inside are for sale. Have two sets of corvette brakes and one set of ls1 f body brakes to sell, some wheels and other misc corvette parts
Crispy
Carbon County, Pennsyltucky
Suburban V1500
What 4th gen brake parts do you have? Wouldnt mind doing the "ls1 brake" upgrade on 65 Skylark.
yevgenievich
Place
Name
Year
Model
Size
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
It's the freeway left-foot brakers that drive in the left lane and hit the b-lights every 100 yards WHEN NO ONE IS IN FRONT OF THEM OR TO THEIR RIGHT!!! AND THEY'RE DOING 5 MPH BELOW THE LIMIT!!!
Umm yeah but that won't be me..
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
I'm the same way. Left foot brake, right foot gas. I've done so much racing and wheeling it's 2nd nature to me now. If I try and use my right foot to brake I put myself through the windshield, lol. When I drive stick I can stop fine with my right foot. It's weird.
Last year I broke my right ankle and had to drive with only my left foot. Right foot was up on the tunnel in front of the 4x4 stick. NOT fun.
yevgenievich
Place
Name
Year
Model
Size
Played with door adjustment yesterday a bit. I think it closes a bit better. It is still a 90's dodge at heart even if it is trying to use door striker mechanism similar to a mercedes. I ended up back at pretty much same spot as it already was. Maybe half a mm difference at most.
yevgenievich
Place
Name
Year
Model
Size
Ah ok. I'm looking for the rear backing plates specifically.
I will have rear disk brakes from my 3rd gen fbody for sale. They are from 94 f body. I like the corvette rear hand brake setup better
Crispy
Suburban V1500
I think that can work. Let me know when they are available and in the mean time I'll do some research.
yevgenievich
Place
Name
Year
Model
Size
Installed short throw shifter. I also cut another inch or so of threads on the handle to make up an inch in shifter being higher. Had to nudge the transmission to one side a bit for shifter to clear going in to reverse. While under the car, decided should change trans fluid and found the reason for light throttle steer. One of rear inner toe rods is bad. Was thinking should replace all steering tie rods and rebuild the steering rack if will need to do alignment. Ordered all dodge Dakota rods, and rack seals. With some modifications should fit. Ordered a die to cut the threads as well.
yevgenievich
Place
Name
Year
Model
Size
Nobody sells Viper tie rods?
There is unknown manufacturer shipped from China for fronts inner. A set of rear still available at $200 per side. And I think I seen somewhere for front sets $500 per side. No rack seal kits available at all. Taking dakota parts and modifying a bit like dodge originally did is a lot cheaper.
KAR1130
