The 4 bolt main LIE !!! Or is it???
Tennessee
Yes, if you search Reo accelerator pump on the Holley site, it will show up. That is where I got the picture.
I was looking for a picture of a Holley on a Reo. Found one on the SteelSoldiers forum, but I needed to be a member to enlarge it. I did join, nobody there today for confirmation.
From an Ebay ad. You can see the bigger pump and app list
Moderator Administrator
From AI:
AI Overview
The Holley "REO" accelerator pump is a heavy-duty, 50cc fuel pump assembly (typically part number 20-11) designed for high-horsepower engines, alcohol/methanol-fueled applications, or extreme-load situations. Standard 30cc pumps are usually adequate for street driving, but REO pumps provide a larger, longer-lasting fuel shot to prevent engine bogging.
Key Details & Upgrades
  • Part Numbers: Complete conversion kits and replacement parts can be found on sites like Holley Accelerator Pump Kits on eBay.
  • Tuning Cams: The pump can be further calibrated using Holley Pump Cams (often part number 20-12), which change the lift and duration of the fuel squirt.
  • Nozzles: Upgrading to a 50cc pump usually requires matching Holley Pump Nozzles to handle the increased volume effectively. [1, 2, 3]
And why do they call it a fuel pump? It is I guess of sorts, but the instant I hear accelerator pump, I know EXACTLY what you're talking about. You tell me 50CC Fuel Pump, I'm going to say, HUH?!?!?
dpenfield
