TH400 trans mount bolts
496bb
AL
CL
Suburban R20
Noticed I am missing one of the two bolts that go through the trans mount on the rear of my 87 R20 Burb's th400. Can anybody help me out with the bolt size/length needed so I can go grab one?
I'm pretty sure there were 2 different possibilities,best bet is pull the one you have and match it. If I just wanted to buy something and go home with too much. I'd buy a 7/16th coarse 7/16th fine and an m10x1.5 all 1.25 long.
Carb'ed Vortec 350
^^^^^THIS^^^^^
Rickf
Grafton NH
1974, 1954 & a 1937
1) I'd get some tools,
2) go to a local hardware store
3) remove one of the remaining bolts
and find something the same size.
But that's me.
Old Guy Bill
KY
Bill
I believe my TH400 mount uses 7/16-14... but it's a '70s unit..
496bb
AL
CL
Suburban R20
That’s what I was thinking too, just wondering if someone knew offhand. 87 was a real mixture of SAE/metric.
496bb
AL
CL
Suburban R20
But that's me.
Wow, one in every group I guess
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
'79 ain't no picnic either. I get tired of the trek back and forth to the toolbox for different basis tools. At my shop, it's a trip up and down stairs outdoors.
Carb'ed Vortec 350
Even my '81 is a mix of imperial and metric. First time I started tearing into things with my imperial tools and couldn't find a size that fit, I knew it was similar to my '91 Cherokee, where I needed a set of tools with both. My setup sounds similar to yours except mine is not up and down stairs, it's a 160-170 feet walk one-way to the tools. That's why I carry a small set in each vehicle, then only the specialty stuff requires "the walk". Even on my Jeep, I had one bolt missing on the trans-mount, went to the hardware store that carries a ton of bolts and screws and still couldn't find an exact match the other. It was a metric bolt, but it has an 11/16 imperial head and that measures 17.4mm, odd duck indeed.
Sad Sack
Nebraska
Goober
C15
Years back, way back, starting in ‘79 the misery started and then I believe (maybe) it was engine SAE and the rest metric. Sucked to have to buy more tools when wages weren’t even $3 an hour. Back then tools weren’t cheap. The 79 Monte Carlo I learned this from back then was an irritating experience.
KWMECH
northern calif
kevin
V2500 Suburban
Probably have it sorted by now but the Metric 10mm size is going to be a 1.5 pitch 25 or 30mm long, not 1.25 pitch. GM never used a fine thread in aluminum. 1.25 pitch is an asian thing
hauto85
