custodian
- Apr 15, 2016
- Catawba
- William
- C10
- 5.3 LS, 350
I'm just about ready to drop the new 350 into my 85 C10. The 350 is a 75 model and the heads are the 87 up TBI 193 heads with the 1.94/1.50, 63.5cc heads.
I had an early set of stock cast iron manifolds, without the AIR holes, I intended to use. Went to bolt them up (mock up to make sure of fit) and found that the bolt holes don't line up.
I measured the bolt holes on the heads and the bolt holes on the manifolds and there was about an 1/8" difference. The manifolds were shorter.
Center to center on the mounting holes on the heads are 17 3/8". Center to center on the manifolds are 17 3/16".
UPDATE: The casting numbers on the exhaust manifolds are 30292 and 30092. They are GM. I don't think they are for the SBC.
UPDATE: I bolted up a set of Ram Horns to the heads.
I know the TBI heads have the extra hole, but did not bother with them.
Now my question: What headers will work on the TBI heads? Short heads that would bolt up to the exhaust pipes would be okay. I haven't searched anything yet.
