SWEET SCORE! Wiper Delay Switch
78C10BigTen
pennsylvannia
C10 BIG TEN
Walking around the swap meet at the bloomsburg nationals and picked up this sweet score for a mere $4!! Super pumped because mine dont work and i just saved about $40.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
And the knob is worth 12 bux !:p
Now if you can find door panels...
78C10BigTen
pennsylvannia
C10 BIG TEN
LOL- no , I bought one along with the new switch that came with it already on.
Hope it fixed your wiper issue - seemed to have fixed mine !:cool:
Im gunna find out soon as i can. If its not the switch im going to replace the wiper motor
It's likely the switch or the module that plugs into the harness needs repaired. Whatever ends up being wrong, if you don't want to repair it, you can send it my way.
78C10BigTen
pennsylvannia
C10 BIG TEN
Wheres the module? And to correct my original post.... mine works but not correctly and will not spray when button is pushed.
The module plugs in between the harness and the switch. It's very likely that the contacts in the switch need cleaned to get your washer to work. With a voltmeter, you can test for 12v and switched ground at the washer pump connector on the wiper motor.
78C10BigTen
pennsylvannia
C10 BIG TEN
how would i go about testing it at the plug?
I actually saw another intermittent wiper switch with a long set of wires to another little black box but i didnt buy it, i just may tomorrow....
The plug should have ignition power at all times on the white-ish colored wire, and ground on the other when the washer is pushed.
Sounds like the other switch had the module with it.
I may buy that one tomorrow just for *****... do you need one?
Actually I do! I think the module in my '79 can be repaired and the switch I think is good. But I really want to add delay to my '78 Burb. I seem to drive in light, misting rain a lot, lol.
78C10BigTen
pennsylvannia
C10 BIG TEN
If i can snag it and dont need it ill shoot it your way. He was asking $15 for the switch and module. Switch had no knob, is that good?
78C10BigTen
pennsylvannia
C10 BIG TEN
I secured it @bucket. A lil more then i wanted to spend but if i dont need it, your on the list
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Hmm - if that switch works, how much?
You could recoup your costs!
:cool:
DamnTexan77
