Summit Cam/Lifter kit Install
garzas23
Brazoria County TX
AJ
Making a few upgrades to my stock 350 while its out. I am putting the edelbrock performer intake, with the edelbrock 1405 600cfm carb, and long tube headers. I want to upgrade my cam while i have the motor out, but was wondering if i could keep my stock push rods and rockers. I just want a little more power with a great sound even a small lope. Anybody have any experience with the summit 1103 cam/lifter kit? Any advice is appreciated Thanks in advance.
Heres some specs:
Basic Operating RPM Range:1,600-5,200
Intake Duration at 050 inch Lift:214
Exhaust Duration at 050 inch Lift:224
Duration at 050 inch Lift:214 int./224 exh.
Advertised Intake Duration:288
Advertised Exhaust Duration:298
Advertised Duration:288 int./298 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.444 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.466 in.
Valve Lift with Factory Rocker Arm Ratio:0.444 int./0.466 exh.
Lobe Separation (degrees):112
http://www.summitracing.com/parts/sum-k1103
Also, it says its the largest camshaft to work with the stock converter.
350runner
tx
Ceasar
Yup that cam will work with all stock components it's basically the same can I have. But mine's a comp cam. With a pinch less duration. You'll like it! :) how much compression do you have?
Swims350
Logan WV
none
we ran the 1102 in a stock 305 and again in a rebuilt 350, it's ok, no real lope, pretty decent torque, nothing special really.
the price is the best thing about them.
Shak379
