Stand Alone Harness
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
Anyone use the stand alone harness's that are advertised for their LS swap? Good, Bad?
A good friend of mine used a harness from PSI for his conversion. It's really nice and works flawlessly.
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
I took my harness and uncurled it and found cut wires.
Blackbeard44
Washington State
andy
6.0 LS
Painless makes a good harness, the summit catalog has a very generic description call painless before ordering.
PSI has a good rep for their products, beware of other online shops there is quite a few companies that will rip you off.
it isnt all that hard to unfunk the stock harness and use the factory fuse block, I had mine like that for a few years but wanted to clean it up so I recently installed a Painless harness. 1 thing I did notice about the painless harness is it seems it was designed for the PCM to mount under the dash and I probably should have done that, but I didnt and it works great.
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
They are a bit pricey, but I'll check into them.
Blackbeard44
Washington State
andy
6.0 LS
A good harness with trans wiring, fan, altenator wiring is gonnna be $700ish dollars, if your motor is DBC it is a little cheaper, there is still alot of wiring even when just stand alone
Blackbeard44
Washington State
andy
6.0 LS
Let me touch up on my last reply.
I hate to be this guy thats gonna trash talk but there are 2 companies I have been ripped off by, both times i was able to get a refumd through credit card company.
1 Swap Specialties in Michigan, owners name is Andy, he is very responsive with emails and questions up until you pay him amd he says 2 weeks it will ship, weeks upon weeks go by, you send email, make a call, no answer no reply, my credit card company gives me 60 days to dispute, I waited till day #50 to dispute.
2 Hot Rod Harness La Habre California. owners name is Chris, he talks one hell of a good game, will always answer phone and feed you non stop lines of BS, before I ordered he told me 2 months because he is so busy, that was understandable so i used pay pal, they give 6 months for a dispute, waited my 2 months called he said hes busy and would bump it up inline, waited another month called him, than he said hes still busy i said okay i will call in 2 weeks, called again and told him if it is not gonna ship in 2 weeks, just give me refund, he promised me it would ship, it didnt, than he tried to get paypal to charge me a restock fee.
It literally took me 6 months to get a new harness for my truck because of bullshitters in the harness building aspect of ls motors.
PSI has a good rep, but by the time i had wasted with everyone else i knew summit would not flake out, I ordered it on a thursday during lunch break, it was delivered on Sunday.
so just be careful with these harness makers and dont let the clock run out on disputing the charges, use a credit card or paypal.
I hope you dont have to deal with what I did.
hunters628
Ellensburg Washington
Hunter
I ordered mine on alibaba. It’s the same harness many US companies sell. My harness was made to order the way I specified for $270 all in delivered to my door 8 days after I placed the order. The quality of the harness and connectors is OEM in my opinion. I’ve had no problems with it at all.
ALL-OF-IT
Nebraska
Adam
323.425844 cubic inches
Camar068
Kentucky
10 yrs Air Force
@ALL-OF-IT That's what I did. For my fuse box I used a Bussman fuse box large enough for daytime running light relays for future upgrade. I got the relays, fusebox, and pins from Mouser. the relays I used were the same type used on the vehicle the engine came from.
I wanted to do my first to "become one" with the harness lol. Quicker troubleshooting because I'd been from one end of it to the other.
climb-101
montana
seth
c2 crew cab
6.0 LS
I used BP Automotive on my truck. they make a great harness and were great to deal with as well as fast getting it to me. I plan on using them for my next harness also. they use all new wires crimped to GM specs and they test everything before it leaves.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
Of course the chinese harness is cheap af. Surprised it’s that much cheaper though.
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
Did the wires in those kits come labeled? I checked into those on ebay, and the sellers will not respond to my question about the wires being labeled. I noticed a set of wires rolled up with no connectors and was wondering about them.
hunters628
Hunter
Mine came with an instruction book. It has a diagram showing what every connector is for and has all the wire colors and their destinations listed. Make it really easy to troubleshoot if needed. The people I ordered mine from were extremely helpful and responded quick.
hunters628
Hunter
This is the seller I bought from. Just submit an inquiry and tell them what year motor and size, what transmission, what style injector plugs you need and they will tell you the cost. Mine showed up 8 days after I ordered it.
https://m.alibaba.com/product/60757...terKey":"7.8.2_share","cacheTime":"1800000"}}
Hard
