Speedometer Drive Gear
Ronno6
South Mississippi
Ron
I have a Muncie M-20 from a Coevette in mu '84 C-10
I am running a 3.73 diff
What speedo gear do I need???
It's not that easy. It will depend on tire size as well. If you are running close to the size tires that came on the Corvette then order gears for a Vette with a 3.73. Otherwise there are online calculators to tell you what gear you need.
Turbo4whl
Downingtown, PA
Wayne
There are a lot more of gear choices for automatic transmission driven gear. Manual trans, many times will use a gear reducer from the drive on the trans to the cable to match the numbers. So you might need a ratio adapter.
Ronno6
South Mississippi
Ron
Can the calibration of the speedo in an electronic dash be programmed??
Here's a little blast from the past. We used to use 5/8th reduction adapter so the kph scale was now the mph scale on the old 85 mph speedos.
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
Driven gears in Muncie M20/21/22 are color coded. Probably 5 or 6 different tooth count. Then there are a least 2 different toothed drive gears. The TCI website has a calculator to find the closest driven gear
hoagster
Air Force Supporting Member
California
K10, 1500
5.3l
Use gps speed on google maps while your driving and see if its close with the gear you have!
Johns C10 Hubcap
