Snowman
Snowman
Vienna,WV
Jason
C30
I have a 1981 C30. Problem is with clutch pedal pivot. The pedal itself where bolt goes through for brake pedal is wore out. When you shove clutch down pedal goes over and hits dimmer switch. Other than a machine shop does anybody have any ideas? Thanks I have looked all over the internet and found nothing.
highdesertrange
kalifornia
mike
k30
so are you saying the tube on the peddle is worn out, or the tube that supports both peddles? either way they can both be replace. the wrecking yard is your friend on this one. don't forget the nylon bushings when reassembling. if the bolt is worn replace that also. highdesertranger
sallyjeank10
