Smog removal and valve cover replacement
79Square
Fairhope, AL
4.1L 250
My alternator went bad on my never-ending newly bought 79 C10 project. When I removed it and took into auto store for testing, the guy asked "when was the last time I changed the oil in my alternator?".... point well taken.
With that said, I realized how bad my oil leak is and that it's coming from front of valve cover. While looking to replace valve cover, and because of all the smog pipes and hoses going everywhere (see pic below), I want to replace it with the basic valve cover.
Looking for help: I want to replace the valve cover and remove smog pipes and put plug bolts in the exhaust manifold. My problem is that I have an integrated cylinder head. Does anyone know where to get a 'non smog' valve cover? What i'm finding with searches are for non integrated only.
Also:
What should be kept? PCV, EGR, etc. (I've already taken out the charcoal canister and the many hoses that go with it)
Will I need to do anything with the carburetor? I have a Rochester Varijet II 2BBL.
And any other advice?
Thanks for your help.
Crispy
Carbon County, Pennsyltucky
Suburban V1500
Holy California Batman!
Keep the PCV, charcoal canister is nice to keep also to reduce fuel smell, not really emissions related. Carb will need to be plugged whevever something was removed. If you get a non commie valve cover you will need to pipe plug the other end of those pipes going in to the valve cover.
Not much more info I can give besides that general info above. I'm sure someone will step in with some details.
legopnuematic
Licensed Junk Dealer
MO
Spencer
everything but the PCV and Charcoal canister can go. After removing all of the other stuff check the timing and maybe give it a degree or two more of initial timing.
Rusty Nail
Cowboy of both Time and Space
Russell
350sbc
That pic is makin the rounds over here, it's really somethin!
I sure would be xxxtra backwards about disturbing all that ****. You're a brave man, good luck Wiseguy!
That tube has got to be worth a ton of money to the right guy...we'd really love to see other pix pliz, we're learning here.
Rusty Nail
Russell
350sbc
serious HERO status @Crispy for the incredibly unneccessary yet thoroughly entertaining note from your local Auto Zone.
Obviously OP's photo leaves a lot to the imagination but i'll .be. danged!
I wouldn't touch that with your....wrench. Not for a hunnert dollars would I upset that apple cart, nosireedybob..
keep it forever.
Yeah - don't do it.
wait for me cuz I wanna help! 91% nervous we're gonna muck it up and itll never run right again.
does it run?
Damnit Jim, we've got.to.have some moar pix.
mean mother f..
we only wanna helppp..
wtf do u know about a Varijet?
No seriously..does it run?
Look man, you could be sitting on a goldmine..i'm just saying....
my advice is take great care and dont tear it up, sell it or run it.
79Square
Fairhope, AL
4.1L 250
Yes, this is a California type mess. It was also in the middle of Jimmy Carter years. I already removed the pipes, etc. I was made aware of some plugs for the holes in the two top 'meatloaf' cans. See link. https://www.summitracing.com/parts/mmp-sm66/overview/make/chevrolet
Since I can't find a integrated head valve cover, I'm going to try it with the plugs, and remove/blockoff EGR. I also pulled the carb and will rebuild it. So I'll adjust carb and timing and hope that it all works out.
Here's a pic after the rat's nest removal.
I'm still looking for a normal valve cover for an integrated head if anyone knows of one.
Thanks.
Rusty Nail
Russell
350sbc
ahh pix!
dude is lookin for a valve cover and im tellin him dont do it! but junior is ready to block EGR and take his Varijet apart..
prolly never run again, I tried to help but it was too late...there's a pix atrocity goin on for proof just like that kid with the yellow trim..:bawl:
i won't watch.Youre on your own kid.
why not just butch an LM7 in it to qualify cool?
godspeed
unfollowed
RoryH19
Rory
R10 Silverado SWB
Also:
Some engineer must have been pissed when they had to add the Cali emissions to the standard one.
I sure he said, I'm going to make this the biggest erector set possible with as many tubes as I can find.
I have never seen anything that elaborate on a square.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
No air pump required - it uses the exhaust pulses to do it's thang. My '94 land Cruiser had one, too, but it did not have the hosing set up like that.
How does the integrated head work, BTW ?
Just one giant casting, block and all ?
91 Jimmy
Central Mass
Rich
You can find the plugs for those tubes at 12bolt.com here: https://www.12bolt.com/store/p174/250_292_EGR_Plugs_Head.html
I have a GM 250 straight six in my homemade skidder with the integrated head. I already pulled a bunch of that crap off of my engine already and it runs great. I'm not sure why anyone is afraid to remove smog equipment unless they live in CA. Did you end up making an erg block plate or did you find one? Also, I can't find a "plain" valve cover either yet. Please share if you do!
bajadiver
