Should I cut more coil?
miky2295
pittsburgh
c10/v20
Big block is tempting. I have a few different ideas in mind for the future of this truck
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
BB will level it out for sure and probably give you your rake you spoke of.lol
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Didn't realize that you flipped the axle...so unless the front settles.....you may want to make certain that the front springs are seated in the upper mount correctly. If the front sits higher still, then you answered your own question in your original post.
Since you stated that you will carry a load in the bed, have you considered air shocks or bags to offset the rear end squatting?
miky2295
pittsburgh
c10/v20
Forgot about the possibility of air shocks guess I would need shock extender brackets also. Didn't want to do bags at this point. If I was going to bag it I'd of wanted to do a 4 link
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
How about coilovers?a bit more predictable then air shocks.
gpmorgan
Tupelo Ms.
greg
I'm seriously thinking about a 4link and coil overs for mine. I need traction and strength. Want to eliminate spring wrap.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I built my own Caltracs for my s10 with pretty sticky 315/35/17s with out issue except clearance I'd hit **** a lot with them
SkinnyG
Canada, eh?!
G
C10 Silverado
350/TH350
Much better to get shorter springs and maintain the number of coils.
Technically, a shorter spring with the same number of coils will be a softer spring.
If the front doesn't settle much over time, just cut 2" off the end of each coil spring at a time to sneak up on the ride height you want.
If you have factory half-ton coil springs in it, consider installing some one-ton front springs. They are quite a bit stiffer (thicker metal), which helps it actually ride better at a lowered height because you won't be bottoming out as much.
miky2295
pittsburgh
c10/v20
I think they are 1/2 ton springs.2 owners before me used it to tow his race car trailer with it and the lady I bought it off of had someone put different springs in the rear that's how I ended up with the 56in springs jammed into the 52 in location. It ride so bad the rest shackles were unrolling off the lower bushing
Wracks81
TN
c10 scottsdale
I just F'd up and cut 1 and 1/2 coils put of mine and it is on the bumpstops. Of course my truck was a 6cyl truck swapped to a 350,so i don't know if they replaced the front springs or not!
smoothandlow84
Steve
Yikes.....If I were you, I would just buy drop coils at this point. The spring rate is better than cut oem coils imho.
xXmutantXx
