Shorter steering column?
Geektrucker
Maine
Joe
Scottsdale Suburban C10
350, Vortec Heads, Hi-rise intake, long tube headers, BIG bump stick
May sound silly, anyone ever shorten their steering column to move the wheel closer to dash? I've got 6" - 8" of space between my aftermarket wheel and the dash, it would be nice to lose 4" or so of that space
Sent from the back woods of Maine via skiddah, cah, and a wicked pissah squarebody
I did, your not going to loose 4 inches. I think it's about 3 inches.
Before:
After:
probably not the best pic to show the difference. I have been planing on do a write up on it. Just have had the time.
74propu
florida
austin
c10s/b c10 s/b c10l/b
5.3 / ?/454 tbi
I did but I needed to do a 30 deg bend under the dash and have the steering lower shaft come threw the firewall at a angel so I used a astro van column . it is about 5 in away form the dash at the wheel
oneluckypops
Sedalia, Mo.
Luke
Before:
After:
in a nutshell, I presume you relocated the mounting bracket on the column and shortened the shaft under the hood?
rolltide1
Louisville Ky
Tyrone
Before:
After:
can you tell me how you shorten the steering column ?
It's a lot of steps, and it's not hard if you think about it. But it would take awhile to write it out.
Scott91370
Burleson, Tx
Scott
Sierra1500
Bringing it back...
We got time.
DrvnDrvr
Bend Or
Al
nvrenuf
Mobile, Al.
I'd be interested to hear more about this swap but the user hasn't be on the board in 5 years. I wonder if it was plug & play or cut & fab? I thought I'd read somewhere that van columns were shorter.
I know there are aftermarket columns but I'm not spending $1k on one. I don't like the shift indicator on the housing but that street rod column looks like a decent option for pre '84 trucks without the wiper and high beam switches in the column.
Scott91370
Burleson, Tx
Scott
Sierra1500
Yeah, I am not spending $1k on a steering column. I'm alreay $8k over budget!
After searching, A LOT, I found a guy who did it by unbolting the retaining collar under thge dash and slid the whole assembly away from him about 2" then used the next set of holes to bolt it back together. Of course had to shorten the rod under the hood the same amount. I'll look into this and if I do it I will take pics.
This is his pic:
nvrenuf
Mobile, Al.
Awesome, I'm looking forward to your findings! I'm guessing you'll have to move the flange at the firewall too?
RanchWelder
Earth
Blazer
355ci
Yah, the stoopid expensive Borgeson Shaft, hurts my eyes every time I get bored and search for one on sale. I have an inner tube wrapped and zip tied over my upper socket joint, just to keep the grease in and the water out. It works OK. Made a Delrin bushing to replace the lower bearing race assembly, using the OEM retaining cover to hold it all in there. I'm tempted to weld it in, but then it can never be repaired, so for now it has a few screws keeping it in place.
If the eBay unit works OK. I'de be interested in seeing how your's came out too.
I was really worried the quality would be off, since the next best pricing is double, or more, from the usual suspects...
DrvnDrvr
Bend Or
Al
On my EBay unit there is no provision for the underdash clamp. I cut the clamp part off the existing column and used that. The ring for the shift lever is right up against the dash bezel. I have to loosen the underdash column clamp to get my instrument panel bezel off. The column came with the correct plug fur ignition signals and stuff.
MikeD
