Shackle flip bracket
Jessica
Driggs Idaho
Jessica
K-10
Hello. As you can see I have an issue with the suspension on my truck, the back and is definitely hiked up after I installed new lift springs. Any ideas on a lowering bracket for the shackle flips? Advice is greatly appreciated!
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Hi Jessica welcome to the site.
So you must have noticed you have shackle flip brackets as your thread title mentions. And so you're adding lift spring under these perches?
The only 'lowering bracket' would be the original stock bracket.
Usually we use the stock springs with a shackle flip, and a zero-rate block to move the axle back an inch.
animal
Lee
c10 silverado
350ish
:welcome:
77 K20
Montana
K20 5" lift
HT383 fuel injected
Can you list the parts you used for the whole truck? What front springs did you order? Did you order new springs and the shackle flip at the same time? What length shackles? Which shackle flip? 2.5" or 4"...
My quick answer would be just put the stock rear springs on.
marks86
Latham, NY
Mark
12v Cummins
A shackle flip is just another way to lift you truck.
TravisB
Travis
Welcome from Kentucky!
I wouldn't mind the rake as much as how it looks like the axle is closer to the front and off center in the wheel well. Good luck, answer the questions above and someone will know exactly what you need.
donnieray
Talks to dogs and trucks.
Roanoke Rapids NC
Donnie
86 C10, 84 K10 MM7 NP833 option truck, 85 K10.
350,355;350.
Hi and welcome. To be sure someone here still has their stock shackle hangers left over from a shackle flip conversion.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Looks like a 4” shackle flip and an 8” skyjacker spring...based on the sticker.
What is the lift supposed to be up front? The rear is essentially a 12” lift.
77 K20
Montana
K20 5" lift
HT383 fuel injected
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
A zero rate will correct this, but lifts up the vehicle 1".
9 times out of 10 that's a good thing.
Stick one up front too, and move that axle forward as well. They like it, and gives more tire clearance where it's needed. Trim some of the 'tooth'
of the fender, Without crazy twisting you can fit 35s like this.
MikeD
