shackle bolts
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
replacing rear shackles I had to cut the bolts because they were rusted to the metal sleeve inside the rubber on the spring eye. Whats the best(easiest) way to get the bolt out of the rubber?
gmc1500
Alabama
Derek
GMC C1500
4.3 V6
Cutting torch
MadOgre
NA
NA
NA
NA
NA
You will have to replace the bushings. Replace the eye bolts with grease able pins
CSFJ
NOPHO84K30
north phoenix
justin
1984 silverado k30
K30 dana 60 corp14 ff
454 sm465 np205
I did same thing on my front leaves i got the ord super shackles greasable bolts busings HUGE difference
MadOgre
NA
NA
NA
NA
NA
Anyone ever get the energy suspension polyurethane bushings that fit stock leaf springs ?
gmc1500
Alabama
Derek
GMC C1500
4.3 V6
I emailed them directly and found out exactly what I needed for my application. Here is the email address to one of the managers he should be able to help and will need the OD of the eye [email protected] hope this helps
lorisa2u
