Seized Brake Drum '78 C30 - HELP!
tpripps
Scandia, MN
Tyler
C30
I am trying to unstick the drivers side rear brake drum on my C30 Project. I've removed the wheel and have beating the tar out of it with a 6# sledge. I'd like to try to preserve it if possible since they're so expensive to replace but I can't do anything with it seized like this. I've also tried prying on the lugs with a pry bar (gently) to try to to put some spin on it. No dice. Next is heat and more pounding. Any suggestions? Y'all have been tremendously helpful so far.
Broken main leaf addressed in a separate post.
SirRobyn0
Hey buddy, that's not a slide off drum. That axle you have is called a full floater and it's on of the best in terms of weight hauling and durability.
To remove the drum you'll need to take the 8 bolts out on the end of the axle, that's those small bolts in your picture. Once those are out the axle will slide out. Inside of that will be a bearing set that will be somewhat similar to a front axle. After you disassembly the bearings the drum will come off.
Turbo4whl
Downingtown, PA
Wayne
Jimmy
Tyler, you better get a book or watch some U tube videos.
That full floating axle drum is held on the hub with all 8 studs.
1) Take off the 8 axle bolts (center)
2) Remove the axle
3) Remove two axle nuts inside the hub
4) Now the hub, bearings and drum will all come off together
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
When you say seized you mean it's stuck to the shoes and won't turn, or as above you're just trying to pull the drum off?
If it's stuck to the shoes you can try to go through the backing plate port and push the adjuster lever out of the way and back off the star wheel to allow the shoes to retract more which may help them unstick.
Turbo4whl
Downingtown, PA
Wayne
Jimmy
Tyler, 2 more quick points: Best to have a heavy piece of plywood under the jack when lifting a truck on a soft surface. A jack stand, also on wood is a missing safety too.
tpripps
Scandia, MN
Tyler
C30
Thanks for the feedback but I had a 2 x 12 under the jack while jacking, now it's just sitting there. There are also 2 jack stands in concrete pads farther back out of the picture. This aint my first rodeo ;-)
FireTruck1984
Michigan
Ted
1984 and 1984
Turbo4whl
Downingtown, PA
Wayne
Jimmy
I am glad to hear this. The picture looked dangerous.
tpripps
Scandia, MN
Tyler
C30
Yes, the drum appears to be seized on the pads, or the bearings are seized altogether. I got the other side to turn but it feels pretty crusty. I'm just assuming the pads are seized to the drum. Eventually I'll want to pull the drum off but for now, I just want the truck to be mobile. i'll try loosening them up.
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
If it's stuck to the shoes you should be able to pick up a slight amount of movement because of slack in the assembly. If not there may be more to it. Let us know how the unloosening goes.
SirRobyn0
That's a picture of me!!!!!
Funny side story, I use to work in shop years ago that the building was built in 1910. It was this funky L shaped building that once had an apartment over the oldest half, which we used for parts storage. The bathroom was added on. It looked like it hadn't been given much love in the last 50 years and the office was extremely small. Yet it the door to the parking lot opened in, against current code it was grandfathered in. The office was so small a notch was cut out of the front counter so the door wouldn't hit it. Despite the signs people would also try to open the door the opposite way. Sometimes it could be quite comical. Sometime I'll have to tell you all a story about that place.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
He said it wont spin, has nothing to do with removing it .
Have you tried backing off the star wheel that sets drum brake adjustment?
Its accessible thru the backplate in a rectangular hole.
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
That's a great idea.
Wish I had thought of that.
