Rusted Frame Question
77frameoff
NC
Ryan
Good morning everyone, I have been searching the forums for awhile and cannot seem to find the name of the brackets or where to order them for my rusted frame parts. After scouring LMC truck I figured now is the time to reach out and see if anyone else might have an idea of what I am looking for.
All of the pictures are taken from the rear of the frame looking forward.
If anyone could help me with where to find these parts for the frame I would be grateful.
I need to replace all three crossmember.
74 Shortbed
Welcome to the site.
highdesertrange
kalifornia
mike
k30
junk yard. why are there lowering shackles on a 4x4? highdesertranger
chengny
77frameoff
NC
Ryan
That's a great question, PO decided to do it said he used it as a hunting rig. I will be swapping them out with a new kit to stuff larger tires. Truck was perfectly level before I started stripping it.
77frameoff
NC
Ryan
chengny
Aw shucks - thanks! But that's not a cheat sheet - it's a parts list.
You noticed the links to rayandsamantha - right?
The structural steel he provides always looks real good and pretty cheap too.
77frameoff
NC
Ryan
Yes I saw it I am going to order them both the cab mounting is different than what I currently have.
chengny
Yeah I noticed that - what's up? Are you sure it's a 77?
77frameoff
NC
Ryan
The Title says 1977, are there any key indicators? I am new to this, the motor I pulled out ended up being a 307 which to my understanding was only put in the 73 model but the rest of the body follows the 77 including vin. Is there a vin stamp on the frame I should be looking for?
chengny
I just looked more closely at the part names section of the image and it provided a clue as to the reason yours looks different than what is shown. Your frame doesn't exactly match the dwg because the frame shown above the parts list is kind of an amalgam/composite. It combines the features of at least 2 (maybe 3) C/K body styles.
Take the body mounting points for example:
A standard cab (03 style) uses only 2 sets of body mounts.
One is the forward set (under the cab floor and outside the rails) which is indicated by part no. 23 - Bracket, Body Mtg #1. This set of mounts is common to all C/K series trucks.
The other set (Body Mtg #2) is located on the cross member shown as part no. 9 (Member, Rear Spring Frt Hanger Cross). And as far as body mounts for the 03 style, that's it.
The Crew Cab series (43) uses identical body mounts in the same two locations - and with the same design - as the 03's.
That second set of mounting points isn't even represented in the dwg.
But the 43 style also has another set of mounts - located under the rear wall of the cab like an 03. Obviously, due to the extended cab length, those mounts are further back on the frame. And instead of a x-member, they are supported by brackets similar to the forward two sets. That is what is shown in the dwg as part no. 11 (Bracket, Body Mtg #3).
So the frame VIN shouldn't be an issue after all. However if you need to know it for some reason, look all along the top flange of the RH frame rail. It could be anywhere on the rail - from the rear wall down into the engine compartment. Also there may be more than one stamping.
BTW - it won't exactly match the VIN. It's more of a frame serial number and should be similar to this - C6S215739. C is for Chevy. Since you have a GMC, your's should begin with a T. Don't ask me - I have no idea.
This is reported to be the key to decode the frame serial/VIN number:
The first ----- letter will be C for Chevrolet or T for GMC.
The second---- C for 2 wheel drive or K for 4 wheel drive.
The third is the engine description .
The fourth is Series for Chev 1=10, 2=20, 3=30 For GMC 1=15, 2=25, 3=35
The fifth is body type 4 = PICK UP
The sixth is Year. 3=73, 4=74, 5=75, 6=76, 7=77, 8=78, 9=79, A=80.
Joestreml
