richmond gear how to tell ratio
coreys87
newyork
corey
v1500
ok guys. i have the covers off my axles and they have richmond gears in them. how can i tell what the ratios on them are?
sean1960
Wylie Texas
Sean
Custom GMC
Divide the teeth on the ring gear by the number of the teeth on the pinion gear.
If you have the covers off, you can count the teeth, or you can look for markings of the teeth on the ring gear. Like a 41-10, would mean 41 teeth on the ring, and 10 on the pinion. Divide the # of ring teeth by the pinion teeth, so 41 divided by 10 = 4.1 which is 4.10 gears. Most gears are marked xx-x (if the pinion is a single digit) or xx-xx (if pinion is 2 digits, 10 or 11 etc) Fairly simple really once the covers are off.
coreys87
newyork
corey
v1500
thanks guys. i just couldnt remember which you divided which by. lol thanks
coreys87
newyork
corey
v1500
ive been beating my brains out. the numbers arnt like you said, its like 5 numbers than a set of 4 numbers but they dont divide right.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
Just count the teeth of the ring gear and pinion and post them here, one of us can work a calculator for you.. :rofl: j/k but seriously just count em and post em here.
coreys87
newyork
corey
v1500
counted em up. 3:73s and 3:08s. the only catch is my truck has 308 in the front already because the previous owner only switched the rear axle to 456 for pulling. should i just put the 12bolt 308 in? or switch the front and rear axle for the 10bolt rear with 373?
crazy4offroad
Curt
K-10
350/SM465/NP205
Just depends on what you want to do with the truck, what size tires are on it or are going to put on it...you gonna do any towing? Offroading?
coreys87
newyork
corey
v1500
Its got 35s with a 305 soon to be 350. i tow a couple fourwheelers occasionally with my 14ft landscape trailer. leaning towards the 373s and findin a 5speed to put in it somehow. anyone done it before?
crazy4offroad
Curt
K-10
350/SM465/NP205
3.73s or 4.11s would be even better, and if you plan to go bigger down the road I would keep the 4.56s under the bench. I dont think it would be real hard to do an NV4500 and I think NP241 transfer case but you'd more than likely have to redo your driveshaft lengths.
coreys87
newyork
corey
v1500
yea i planned on keeping everything. looks like ill throw the 373s in it.
coreys87
newyork
corey
v1500
so i cant use the current transfercase? curious as to why... thnaks
crazy4offroad
Curt
K-10
350/SM465/NP205
You might be able to if the adapter between the t-case/trans is the same, and the adapter sleeve is the same spline count, and/or if you can find an NV4500 from as close to the same production year as your truck as you can get. I think those had a really low 1st gear. Hopefully someone who knows for sure can chime in, otherwise google will have to be the way to find out.
What tranny is in it now? If its a 700r4, keep the 4.56 in the rear and do the front to match. If it's the 465 shift-it-yourself, then yeah, the 3.73's would be fine.
coreys87
newyork
corey
v1500
has the sm465
Wrenchersllc
