Frankenchevy
Proverbs 16:18
- Jan 3, 2018
- USA
- Jeremy
- Square
- CUCV
- Small
I've been stripping the engine bay, preparing for paint and new engine install.
I've never lost water from my cooling system. the level has always remained full. I found some residue near one of the necks that looks like it was caused by a tiny pinhole misting in. again, every time I opened the radiator cap the coolant has always appeared topped up and clean looking.
so I was going to have the radiator tested and repaired if necessary at a radiator shop. I was ballparked at $160. a new radiator replacement ranges from $230 for a Champion at jegs http://www.jegs.com/i/Champion-Cooling-Systems/166/CC716/10002/-1#reviewTab that gets good reviews to a Mishimoto at summit for $320 https://www.summitracing.com/parts/mio-mmrad-ck-78x/reviews/?filterReviews=ThreeStar
what are the benefits to repairing oem radiator other than it looking better than the aluminum bling pieces and the $70-160 difference? which is the better radiator stock or aftermarket aluminum? cost isn't that big of a factor, as I'm looking at it being spread out over the lifetime of the vehicle. just curious about the pros and cons of each type.
