Rear Wheel is Stuck !!
rusted nuts
Pa.
Jeffrey
k20
4cly diesel
reverse the clamps on a pipe clamp and make a handle like on a bench vise?
All Ya need is a BFH.
drumvirt
Virginia
Danny
C-30
Spent the last 3 hours sweating my face off trying to remove a stuck wheel. the other 3 came off no problem, rear driver... not so much
can of liquid wrench....check
Beat rim for hours....check
Drove short distance with lugs loose ..... check
Said a few four letter words in front of my daughter .... check
Pryed and beat some more .... check
you get the point lol
are there any secrets of tricks... I used a 5 lb sledge, i dont have a bigger one... yet
Try "Prayed and beat some more".
drumvirt
Virginia
Danny
C-30
Search "Wheel Stuck on Drum" in this forum. One of the last threads suggests using oxy torch for fast temp rise of the heated part and lag time heating the part you want to stay cool. Follow with PB blaster while warm but watch out for flame development and have extinguisher handy. Let us know how it turns out.
Camar068
10 yrs Air Force
Good idea, but that was already mentioned by a few as well as the poster. Trying to think outside of the box and give another option.
Take off the diff cover,remove the cross pin bolt and cross pin. Push in on the axle and pull the retaining clip. Now slide out the axle take the axle with wheel and tire to the machine shop and have the axle pressed out. Problem solved. @Camar068 is that far enough out of the box?
Camar068
10 yrs Air Force
Take off the diff cover,remove the cross pin bolt abd cross pin. Push in on the axle and pull the retaining clip. Now slide out the axle take the axle with wheel and tire to the machine shop and have the axle pressed out. Problem solved. @Camar068 is that far enough out of the box?
yup, sounds like an easy option to me :)
satansdad
