Quadrajet Linkage
firebane
Calgary, AB
Curtis
So I found out the carb I have on my truck right now doesn't have the part to allow the cable for my th350 to be hooked up. I was thinking...
1) Would it be ok to drill above where it normally goes in?
2) Does the th350 cable really care about the angle its used at?
Red = Missing
Blue = Drill Out
I don't want to have to swap shafts if I don't have to lol.
Just bolt a universal linkage stud into the hole. You probably have the cable that just slides over a stud, correct? Or is it a newer style that snaps over a stud that looks like the head of a nail? Either type is available, and a lot of auto parts stores carry them in the "performance" isle.
firebane
Calgary, AB
Curtis
The red circle was cut off :p Which hole are you talking about lol.
The red circle.
Is the end of your cable metal or plastic?
firebane
Calgary, AB
Curtis
The red circle.
I'm thinking your confused about something lol. My current arm looks like this..
In the picture I provided the top stud is for the throttle linkage and the lowest hole is for the throttle return springs. I need one more hole for the detent cable which has the end like this.. http://www.ss396.com/mm5/graphics/00000001/S530.jpg
Ah, yep I misunderstood. I thought the first pic WAS your throttle linkage.
I think it would be best to change the linkage or at least weld a piece of steel back on there so you can hook the cable up in the correct spot. If you drilled a hole in what you still have left, it would hardly have any pull on the cable.
Mudbeast2
