Q: re - can anyone ID this ?
BigDaddy Mich
North Carolina, United States
Mick
I've asked as many GM Guys that I know, and everyone says "I've NEVER seen a valve cover like that before in my life" - Does anyone have an idea if this a standard issue thing?
My C-10 is a bare-bones (non-California) 2WD long bed with a 4.1 and a manual 3spd (column). I'm just curious why this valve cover looks like it's from a V 8-6-4 Cadillac lol.
Any opinions/ideas welcome.
Thanks, fellas.
Keith Seymore
Motor City
Keith Seymore
4.3L
That absolutely is a regular ole 250 cu in straight six valve cover. For use with the integral head intake/exhaust setup.
Heritage Center info packet link:
My 80 Chevy stepper had that.
K
Hilllbilly
PNW
Elon
k20, c10
OP... post us a picture of the intake/exhaust side of the head
The "all knowing internet" says the integrated heads are prone to cracking , the internet says
Moderator Administrator
Tis True. Very Prone to Cracking, and not where you'd think. They like to crack in the threads, even the water pump mounting threads. I rebuilt one for a guy in the late 80's. Had his head magnafluxed, it was cracked. It took me the 5th head from the junk yard to finally get one that the machine shop didn't find a crack in. The guy wanted me to just convert it to an older 250 head. I couldn't do it due to being in Cali and smog licensing inspection requirement. He'd have never passed smog.
BigDaddy Mich
Mick
K
THANK YOU so much for the reply! I love this truck - it just seemed weird to me. NOW we KNOW! ~ BD
Now that you know what it is, I'll go ahead and give permisison for an engine swap on that truck. IF it was the older I6 without the integrated head, I'd say NOOO, that's against the rulz, keep the I6 in it. But this monstrosity uglier than a red headed step child, feel free to swap it out. They're not as reliable as the older ones. The bottom end is, but that head wiht the intake set up and such, it's just ugliness and as said, heads are prone to crack. I'll add though, many times the heads will crack and you won't even know it. It'll just keep runnin and runnin, just like Forrest Gump. So basically it can have a superficial crack. Meaning, it'll be cracked but really not affecting anything YET. As the crack grows, it'll eventually start affecting something. You could even just convert the head to the older style and keep the shott block if you wanted to.
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
Lousy head used from 1977-84. I'd find a 1977 and earlier non-integral head, slap in on and keep cruising.
Sad Sack
Nebraska
Goober
C15
Had a 1975 Camaro with an integral head 250 - hated it. Car ran great but notorious for problems with cracking.
BigDaddy Mich
Mick
Yep and 350s eventually wear out the rings,rod bearings,and valve,seals, eventually,so we should probably just go ahead pull them now before they have problems and swap in LT4s.
justhorns
Denver
Lee
Just remember, you will need new intake and exhaust manifolds and have to re-do the front exhaust pipe that leads to the catalyst.
justhorns
Denver
Lee
For my 250 IH I have the early head on the shelf for change out one day soon. When I get some $$
JBswth
Vallejo, California
James
C25
292 cubic inches
.. but if smog / emissions regulations aren't an issue, CAN you change to the older style head ? Curious.
Yes you can! You might have a very hard time finding the correct bracket set for the accessories, but once you have everything buttoned up, you will be good to go. If you have progressive 2 barrel carb, you will have to switch to a 1 barrel of the correct era.
jw23655
