Pulleys
Skweegle89
Oklahoma
I have a new pair of billet aluminum pulleys that I believe fit a 454. Slightly larger than my sbc pulleys. I also have a set of copper header gaskets for a 454. Make me an offer I can't refuse.
cobra20
Portland, Oregon
Hans
V1500 Suburban, K5 Blazer
5.7L
how many grooves on the crank and water pump pulley. How big is the hole in the crank pulley
Skweegle89
Oklahoma
2 grooves on each pulley. Center hole on crank pulley is 1"
Skweegle89
Oklahoma
Nobody?
I'm surprised @bucket aint taking a interest in them.
Yeah, me too. Actually I keep forgetting to go look at my truck and see how many grooves I have. But I do think it's 2 grooves.
Skweegle89
Oklahoma
Make me an offer if you want them. I have those header gaskets too. I put the alternator on my new crate motor though. I have the stainless hardware for the pulleys as well. If you would, measure your alternator pulley so I can make sure they are for a big block.
I think it's the pulley depth that matters. I've got original GM small block pulleys that are different sizes than others. I think older setups generally had larger pulleys.
Skweegle89
Oklahoma
Oh I gotcha. I don't have the power steering pulley btw. Just the crank and water pump.
Not to butt in, but short water pump, and long water pump do make a difference.
Yep, they do. The ones in the pic look like they might be the tall style.
Were there part #'s to go along with the pulleys?
Skweegle89
Oklahoma
I will check tomorrow, they are probably on the invoice sheet.
loki1978
