PSI 8.8L big block
Moderator
Thomas rates it at 339hp 560 ft/lbs.
A real boat anchor :D
Yeah, but what is that figure at? 2k? Lol.
With proper valve springs (if they aren't already), do you know about what rpm actual peak power is and what that figure could possibly be?
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
You guy's are whacky lol.
I do not care one whit what the stock power rating is, at what rpm, under what astronomical sign, if Venus needs to be in retrograde...
I will never so much as crank this 540 inch engine one starter revolution with it's 80 lb valve springs, .480 lift cam.
So no, I don't know, or care what RPM actual peak power is as it sits. I'm not even going to spend a single second Google searching it.
Whole ass engine, as is, cam and spring swap, hang my S480 off the side, go party. That's what's happening here.
Moderator
I was just wondering, because if it's anything like a lot of agricultural stuff, they have a rating at 2k or 2200, no matter how much power they may or may not make above that.
There's probably a lot of people that will scoff at that 339hp rating and not get the point.
Jrgunn5150
Ionia Mi
J.R.
6.slow
For sure.
My intention is to just cam it like a 540, I'm really confident, it will respond like a 540 lol.
But 100%, it's designed to be lazy AF and sit on a governor.
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
So I don't understand.....you are building a high dollar, high horse, high torque engine..............and then let it sit on a governor?.....Governor set at 6 grand?
Jrgunn5150
Ionia Mi
J.R.
6.slow
You don't understand.
I'm building neither a high dollar engine nor letting it sit on a governor.
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
You are absolutely right........I DON'T understand and at this point, I don't really care
Jrgunn5150
Ionia Mi
J.R.
6.slow
Cool, do you need me to show you how to turn off notifications and leave the thread or do you have it under control?
Moderator
It's the later evolution of GM's 8.1, after it left the hands of GM. It has a crap ton of power potential, but it is primarily used in busses, stationary equipment etc. The kind of stuff that is rated for a certain rpm and that's where it is regulated to spend all it's time.
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
No I' m good, thanks anyway.......... and so Andy @bucket .....it's an ag engine?.......I guess I still don't care
CountKrunk
SW VA
Count
C20 Custom Deluxe 3+3
v8 350
So what is the plan for the 8.8?
Hunter79764
Grand Prairie, TX
Suburban V20
Fair to say it WAS an Ag engine, but the planned cam, springs, and turbo should very much leave that rating in the dirt.
I'm interested in this build, I'm planning an 8.1 swap (and yes, I understand it is a jump from the 8.1, but still close enough to be interesting), all of these late model big blocks are pretty cool in my book.
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
Craig
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
I have a BW475, that 480, even 6 lb of boost will make huge torque numbers, probably less HP, BUT, will pull a house. I sure would like to mess with one, never had a chance to machine a block like this..
Nborden88
