flyboy1100
- May 23, 2014
- UsA
- me
- k1500
- 305, 700r4??, 3.42 gears
are they going to be the same if the carb came off a '86 Burb w/ 350 as my '86 305? http://www.ebay.com/itm/291235371952 i did buy it and overall it looks close, i wish there was a direct picture of the drivers side so i could see the linkages but i think it is the same or simiar
reason:
i was trying to retap the holes in the primary shaft since 1 screw sheared on removal and i ended up snapping the tap in the hole and i don't know how to or if it is even possible to remove it.
and i am missing some parts i would like to get back that look like they are on that carb.
i am only planning to take what i need (throttle shaft, idle solenoid, choke housing) and leave the rest unless it is better than mine.
reason:
