texasmike
- Sep 18, 2018
- Conroe Texas
- Mike
- C10
I recently noticed that battery water was coming out of two of the front three cells. The level in the middle cell was normal but the level in the cells on either side was lower but was still above the plates by about 3/4". I removed the battery, cleaned the mess and corrosion up, repainted the tray and put the battery back in. I decided not to add any water to the low cells and drive it for a while, keeping an eye on it.
It's been a few hundred miles and it's still doing the same, only not with the big mess. Here's what I know: it has an Exide battery that is 37 months old and the specific gravity in all six cells shows good. It has an Ultima 78 amp re-manufactured alternator which has about 2,000 miles on it. The battery readings are: Engine Volts
Off 12.90
On 14.51 at idle
On 14.34 at idle with AC and both hi & lo beam on
On 14.40 at 1,800 rpm with AC and all headlights on
What's next?? As always, thanks ahead of time for any help/suggestions.
Off 12.90
On 14.51 at idle
