Plug Gap - Suggested or Altered with HEI?
Dejure
Eastern Washington
Kelly
C15
My new truck, a 78 C15 step side, has a swapped out 350 with HEI (Accel). I'm running the shorty plug equivalent.
Anyway, since the engine has HEI, should I open up the gap a bit more than the oft recommended .35 gap?
legopnuematic
Licensed Junk Dealer
MO
Spencer
A 78 would have had HEI regardless (1974 was the last year for points as std, 1975 HEI was standard, with option to delete for points).
Anyways, .040-.045 should be just fine.
75gmck25
Northern Virginia
Bruce
GM confused things back the day by initially recommending a gap as wide as .060, which was apparently intended to get a better mixture/burn for emissions. However, they quickly realized their mistake, and since then it’s been .035-.045 for most HEI engines.
1STLS1
West Phoenix AZ
MIchael
I thought it was .080. First couple years HEI used to burn the rotor up as a result.
Original
